frem Geschrieben May 7, 2019 at 19:26 Share Geschrieben May 7, 2019 at 19:26 Hi, I've got a setup with two master bricks with wifi extension and Remote Switch Bricklet connected to each. The problem is, that I always get the following error: "COMMAND no tinkerforge device found for command for item uid: EGJ subId: OG_R_Schlafh" I get this error for all devices with uid EGJ Also deleted /var/lib/openhab2/config/org/openhab/tinkerforge.config to clear the cache, but that did not help... Any idea, why this is happening? Below is my tinkerforge.cfg Thanks and best regards Burkhard tinkerforge:hosts=192.168.0.133:4223 192.168.0.75:4223 tinkerforge:ars1.uid=jMm tinkerforge:ars1.type=bricklet_remote_switch tinkerforge:ars1.typeCDevices=EG_L_WZ EG_L_Flur EG_R_WZ EG_R_EZ EG_R_KU tinkerforge:brs2.uid=EGJ tinkerforge:brs2.type=bricklet_remote_switch tinkerforge:brs2.typeCDevices=OG_R_GZR OG_R_GZL OG_L_Schlaf OG_R_Schlafv OG_R_Schlafh ### Erdgeschoss #Licht tinkerforge:rs_EG_L_WZ.uid=jMm tinkerforge:rs_EG_L_WZ.subid=EG_L_WZ tinkerforge:rs_EG_L_WZ.type=remote_switch_c tinkerforge:rs_EG_L_WZ.systemCode=O tinkerforge:rs_EG_L_WZ.deviceCode=1 tinkerforge:rs_EG_L_Flur.uid=jMm tinkerforge:rs_EG_L_Flur.subid=EG_L_Flur tinkerforge:rs_EG_L_Flur.type=remote_switch_c tinkerforge:rs_EG_L_Flur.systemCode=O tinkerforge:rs_EG_L_Flur.deviceCode=9 # Rolladen tinkerforge:rs_EG_R_WZ.uid=jMm tinkerforge:rs_EG_R_WZ.subid=EG_R_WZ tinkerforge:rs_EG_R_WZ.type=remote_switch_c tinkerforge:rs_EG_R_WZ.systemCode=O tinkerforge:rs_EG_R_WZ.deviceCode=10 tinkerforge:rs_EG_R_EZ.uid=jMm tinkerforge:rs_EG_R_EZ.subid=EG_R_EZ tinkerforge:rs_EG_R_EZ.type=remote_switch_c tinkerforge:rs_EG_R_EZ.systemCode=O tinkerforge:rs_EG_R_EZ.deviceCode=11 tinkerforge:rs_EG_R_KU.uid=jMm tinkerforge:rs_EG_R_KU.subid=EG_R_KU tinkerforge:rs_EG_R_KU.type=remote_switch_c tinkerforge:rs_EG_R_KU.systemCode=O tinkerforge:rs_EG_R_KU.deviceCode=3 ## Obergeschoss #Licht tinkerforge:rs_OG_L_Schlaf.uid=EGJ tinkerforge:rs_OG_L_Schlaf.subid=OG_L_Schlaf tinkerforge:rs_OG_L_Schlaf.type=remote_switch_c tinkerforge:rs_OG_L_Schlaf.systemCode=O tinkerforge:rs_OG_L_Schlaf.deviceCode=5 #Rolladen tinkerforge:rs_OG_R_GZL.uid=EGJ tinkerforge:rs_OG_R_GZL.subid=OG_R_GZL tinkerforge:rs_OG_R_GZL.type=remote_switch_c tinkerforge:rs_OG_R_GZL.systemCode=O tinkerforge:rs_OG_R_GZL.deviceCode=14 tinkerforge:rs_OG_R_GZR.uid=EGJ tinkerforge:rs_OG_R_GZR.subid=OG_R_GZR tinkerforge:rs_OG_R_GZR.type=remote_switch_c tinkerforge:rs_OG_R_GZR.systemCode=O tinkerforge:rs_OG_R_GZR.deviceCode=15 tinkerforge:rs_OG_R_Schlafv.uid=EGJ tinkerforge:rs_OG_R_Schlafv.subid=OG_R_Schlafv tinkerforge:rs_OG_R_Schlafv.type=remote_switch_c tinkerforge:rs_OG_R_Schlafv.systemCode=O tinkerforge:rs_OG_R_Schlafv.deviceCode=13 tinkerforge:rs_OG_R_Schlafh.uid=EGJ tinkerforge:rs_OG_R_Schlafh.subid=OG_R_Schlafh tinkerforge:rs_OG_R_Schlafh.type=remote_switch_c tinkerforge:rs_OG_R_Schlafh.systemCode=O tinkerforge:rs_OG_R_Schlafh.deviceCode=6 Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
theo Geschrieben May 7, 2019 at 19:46 Share Geschrieben May 7, 2019 at 19:46 Hallo Burkhard, schau doch mal im Log ob dein EGJ Bricklet erkannt wurde oder ob es Fehlermeldungen gab. Gruß, Theo Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
frem Geschrieben May 8, 2019 at 18:55 Autor Share Geschrieben May 8, 2019 at 18:55 Hi Theo, erstmal vielen Dank für deinen Tip. Ich habe mal das logging für tinkerforge auf debug gesetzt und einen openhab restart gemacht. Ich sehe im Log, dass die config korrekt geparsed wird, aber ich sehe nur die folgende Zeile für das bricklet jMm, eine ähnliche Zeile für EGJ sehe ich nicht: 2019-05-08 20:13:02.274 [DEBUG] [kerforge.internal.TinkerforgeBinding] - TFINIT adding/enabling device jMm with config: org.openhab.binding.tinkerforge.internal.model.impl.BrickletRemoteSwitchConfigurationImpl@1cdd1fe (typeADevices: null, typeBDevices: null, typeCDevices: EG_L_WZ EG_L_Flur EG_R_WZ EG_R_EZ EG_R_KU) Ich habe das log angehängt...ich habe einige exceptions beim Start von openhab die mir aber nicht nach dem selben Problem aussehen...hängt es vielleicht doch damit zusammen? Gruß Burkhardopenhab.log Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
theo Geschrieben May 8, 2019 at 20:56 Share Geschrieben May 8, 2019 at 20:56 Hallo Burkhard, könnte eine race condition sein. Laut Log werden beide Master Bricks erkannt und auch beide Remote Switch Bricklets, aber nur auf das jMm Bricklet wird das "enable" aufgerufen. Das Auftauchen der Bricks/Bricklets und die Verfügbarkeit der Config sind asynchron, das muss das Binding handeln, hier könnte ein Bug sein. Du könntest versuchen OH zu starten wenn nur einer oder keiner der Master Bricks online sind und dann die Bricks erst nach Beendeten OH Startup anschalten. Das ist aber eine wilde Vermutung, ich hab nicht in den Code geschaut, da dieser EOL ist und ich nichts mehr fixen kann. Im besten Fall finden wir einen Workaround. Ein natives OH2 TF-Binding ist in Arbeit aber das RemoteSwitch Bricklet wird derzeit noch nicht unterstützt. Das wird kommen, kann aber noch ein paar Monate dauern. Gruß, Theo Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
frem Geschrieben May 9, 2019 at 20:21 Autor Share Geschrieben May 9, 2019 at 20:21 Hallo, ich habe das Problem gefunden. Ich habe nicht gewusst, dass RemoteSwitch 2.0 nicht kompatibel mit dem Openhab binding ist. Beim experimentieren mit dem deaktivierten Masterbrick habe ich ich dies durch Zufall festgestellt. Der Bricklet wird vom openhab Plugin deshalb scheinbar nicht richtig erkannt. Gruss Burkhard Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
theo Geschrieben May 13, 2019 at 20:15 Share Geschrieben May 13, 2019 at 20:15 Ja klar, das RemoteSwitch 2.0 wird nicht unterstützt da musst du leider auf das neue Binding warten. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
