vetlesillerud Geschrieben January 22, 2019 at 09:20 Share Geschrieben January 22, 2019 at 09:20 Hello, I am currently planning a project that involves connecting the IMU 2.0 with another device that supports PPS synchronization. I can not find any way to synchronize the IMU with the PPS signal. Do any of you have any suggestions on how to do this with or without PPS? Thank you! Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben January 28, 2019 at 16:29 Share Geschrieben January 28, 2019 at 16:29 A synchronization directly on the Brick is unfortunately not possible. You can only get the PPS signal from a GPS Bricklet 2.0 and use that as a trigger to call a getter from a IMU Brick 2.0. What application do you have in mind for the synchronization? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
