rtrbt Geschrieben November 9, 2018 at 10:35 Geschrieben November 9, 2018 at 10:35 Hi, As of yesterday, a beta version of the rust bindings is available. Please tinker around with them and post any bugs, suggestions and other feedback here. The current version of the bindings is attached to this post, including example sources and an example project, which enumerates connected devices. The bindings can also be installed using Cargo by listing tinkerforge = "2.0" in the [dependencies] secion of a project's Cargo.toml. The bindings require a nightly version of the rust compiler, or the current beta release (version 1.31), which will be released as stable on the 7th of december, according to the road map. The beta can be installed with rustup install beta and then can be used with cargo +beta build. Also it is possible to set the beta as the default compiler with rustup default beta, which allows compiling without additional arguments. Nearly all get and set functions and callback registrations are asynchronous, as they return a wrapper around a Receiver, that converts received bytes into structured data. More information can be found in the binding's readme and here. The documentation on the Tinkerforge home page is not visible yet, as it is still work in progress. Have a lot of fun! Eriktinkerforge_rust_bindings_2_0_3.ziptf_rust_example.zip Zitieren
rtrbt Geschrieben December 21, 2018 at 14:31 Autor Geschrieben December 21, 2018 at 14:31 The rust bindings have left the beta phase and are now available on the Tinkerforge home page: https://www.tinkerforge.com/de/doc/Downloads.html Zitieren
