wbackup83 Geschrieben August 7, 2018 at 11:04 Geschrieben August 7, 2018 at 11:04 I don't understand why using a mifare tag using the provided code i can read the tag page without authenticating ...moreover the state page ready is never accessed... for this reason the page if i change the tag still remains the same... can you take a look at my code to understand if i m missing something or what? Tags are found, i can print the page content without authenticating it...(commented) public class ExampleScanForTags { private static final String HOST = "localhost"; private static final int PORT = 4223; // Change XYZ to the UID of your NFC/RFID Bricklet private static final String UID = "uqB"; private static short currentTagType = 0; // Note: To make the example code cleaner we do not handle exceptions. Exceptions // you might normally want to catch are described in the documentation public static void main(String args[]) throws Exception { IPConnection ipcon = new IPConnection(); // Create IP connection // Note: Declare nr as final, so the listener can access it final BrickletNFCRFID nr = new BrickletNFCRFID(UID, ipcon); // Create device object ipcon.connect(HOST, PORT); // Connect to brickd // Don't use device before ipcon is connected // Add state changed listener nr.addStateChangedListener(new BrickletNFCRFID.StateChangedListener() { public void stateChanged(short state, boolean idle) { //System.out.println(state); try { if(idle) { currentTagType = 0; //(short)((currentTagType + 1) % 3); nr.requestTagID(currentTagType); } if(state == BrickletNFCRFID.STATE_REQUEST_TAG_ID_READY) { BrickletNFCRFID.TagID tagID = nr.getTagID(); String s = "Found tag of type " + tagID.tagType + " with ID [" + Integer.toHexString(tagID.tid[0]); for(int i = 1; i < tagID.tidLength; i++) { s += " " + Integer.toHexString(tagID.tid); } s += "]"; System.out.println(s); //added code short[] keys= {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; //nr.authenticateMifareClassicPage(5, (short) 0,keys); short[] data=nr.getPage(); System.out.println(Arrays.toString(data)); } if(state == BrickletNFCRFID.STATE_AUTHENTICATING_MIFARE_CLASSIC_PAGE_READY) { System.out.println("Ready"); } if(state == BrickletNFCRFID.STATE_AUTHENTICATING_MIFARE_CLASSIC_PAGE_ERROR) { System.out.println("error"); } } catch(Exception e) { System.out.println(e); } } }); // Start scan loop nr.requestTagID(BrickletNFCRFID.TAG_TYPE_MIFARE_CLASSIC); System.out.println("Press key to exit"); System.in.read(); ipcon.disconnect(); } } Zitieren
borg Geschrieben August 7, 2018 at 19:53 Geschrieben August 7, 2018 at 19:53 I think if you call getPage you will get the page from the last successful read. So if you call getPage in the REQUEST_TAG_ID_READY state, you will not actually read a new page. You have to first authenticate, then request the page and then you can call getPage. Zitieren
wbackup83 Geschrieben August 7, 2018 at 20:14 Autor Geschrieben August 7, 2018 at 20:14 Thanks for the reply...but it is the same: it always returns the same page with different tags and the other states are never accessed. nr.addStateChangedListener(new BrickletNFCRFID.StateChangedListener() { public void stateChanged(short state, boolean idle) { //System.out.println(state); try { if(idle) { currentTagType = 0; //(short)((currentTagType + 1) % 3); nr.requestTagID(currentTagType); } if(state == BrickletNFCRFID.STATE_REQUEST_TAG_ID_READY) { BrickletNFCRFID.TagID tagID = nr.getTagID(); String s = "Found tag of type " + tagID.tagType + " with ID [" + Integer.toHexString(tagID.tid[0]); for(int i = 1; i < tagID.tidLength; i++) { s += " " + Integer.toHexString(tagID.tid); } s += "]"; System.out.println(s); //added code short[] keys= {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF}; nr.authenticateMifareClassicPage(5, (short) 0,keys); nr.requestPage(5); short[] data=nr.getPage(); System.out.println(Arrays.toString(data)); } if(state == BrickletNFCRFID.STATE_AUTHENTICATING_MIFARE_CLASSIC_PAGE_READY) { System.out.println("Ready"); } if(state == BrickletNFCRFID.STATE_AUTHENTICATING_MIFARE_CLASSIC_PAGE_ERROR) { System.out.println("error"); } } catch(Exception e) { System.out.println(e); } } }); // Start scan loop nr.requestTagID(BrickletNFCRFID.TAG_TYPE_MIFARE_CLASSIC); System.out.println("Press key to exit"); System.in.read(); ipcon.disconnect(); Zitieren
wbackup83 Geschrieben August 7, 2018 at 20:17 Autor Geschrieben August 7, 2018 at 20:17 What i would expect it would be to access the STATE_AUTHENTICATING_MIFARE_CLASSIC_PAGE_READY state after calling authenticateMifareClassicPage(). But this does not happen... Zitieren
borg Geschrieben August 7, 2018 at 20:26 Geschrieben August 7, 2018 at 20:26 If you comment in the "//System.out.println(state);", do you get any new state after you call authenticateMifareClassicPage()? Or no new state at all? Zitieren
wbackup83 Geschrieben August 8, 2018 at 05:56 Autor Geschrieben August 8, 2018 at 05:56 If you intend as it is reported there with the print of the state commented, NO, I do not get any state at all... Zitieren
borg Geschrieben August 8, 2018 at 07:17 Geschrieben August 8, 2018 at 07:17 Strange, do you now what kind of mifare classic tag you have? Is it something special? Do you have a second one you could test with? Zitieren
wbackup83 Geschrieben August 8, 2018 at 07:26 Autor Geschrieben August 8, 2018 at 07:26 https://www.amazon.it/gp/product/B01FLOQNMI/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 I have these... I tried with another tag of the same brand and it's the same... Zitieren
borg Geschrieben August 8, 2018 at 08:19 Geschrieben August 8, 2018 at 08:19 Looking at your code, you do: nr.authenticateMifareClassicPage(5, (short) 0,keys); nr.requestPage(5); short[] data=nr.getPage(); System.out.println(Arrays.toString(data)); I think you should first call nr.authenticateMifareClassicPage(5, (short) 0,keys); then in the state STATE_AUTHENTICATING_MIFARE_CLASSIC_PAGE_READY call nr.requestPage(5); and then in the state STATE_REQUEST_PAGE_READY call short[] data=nr.getPage(); System.out.println(Arrays.toString(data)); Does it work when you do that? Zitieren
wbackup83 Geschrieben August 8, 2018 at 10:09 Autor Geschrieben August 8, 2018 at 10:09 Nope...it does not enter in the state ...never.. I attach the java file so you can try it if you want thanks again for the supportExampleScanForTags.java Zitieren
borg Geschrieben August 8, 2018 at 12:02 Geschrieben August 8, 2018 at 12:02 Hi, it works after a few tweaks: olaf@pc2:~/build20/java$ javac -cp Tinkerforge.jar:. ExampleScanForTags.java olaf@pc2:~/build20/java$ java -cp Tinkerforge.jar:. ExampleScanForTags Press key to exit Found tag of type 0 with ID [6d b8 97 f7] Ready page ready [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0] The Problem with your code is that you call "nr.requestTagID(currentTagType);" every time that the Bricklet is in idle state. But it goes into idle state after it reaches any of the new states. So you call requestTagID in a loop. For me it started to work immediately after i commented out the if(idle) {...} block. Zitieren
wbackup83 Geschrieben August 8, 2018 at 12:51 Autor Geschrieben August 8, 2018 at 12:51 can you please attach the code or paste it? Zitieren
borg Geschrieben August 8, 2018 at 13:22 Geschrieben August 8, 2018 at 13:22 See attachment. Edit: Dont forget to change the UID back to yours.ExampleScanForTags.java Zitieren
wbackup83 Geschrieben August 8, 2018 at 13:35 Autor Geschrieben August 8, 2018 at 13:35 This works if I put the tag on the reader when i run the main... What i need is to scan and be active for other tags ... for this reason I don't understand where to put the loop ... Zitieren
borg Geschrieben August 8, 2018 at 13:48 Geschrieben August 8, 2018 at 13:48 Well, if no tag is there you will get into the state STATE_REQUEST_TAG_ID_ERROR and you have to run requestTagID from there again. I attached a working program that runs in a loop. Please note: All of the steps can create an error. For example: What happens if someone removes the card after the authentication but before the page was read? In this case you probably want to scan for a tag again. You have to handle all of these states if you want it to be robust.ExampleScanForTags.java Zitieren
wbackup83 Geschrieben August 8, 2018 at 14:06 Autor Geschrieben August 8, 2018 at 14:06 It works like a charm! thanks again for your kind support...I really appreciated Zitieren
