One for the developers and hopefully not a difficult change.  The IMU v2 based on the Bosch BNO055 which has more 'sensor fusion modes' than we have options for.
In testing the unit I have found that the FMC (fast magnetometer calibration) is troublesome and makes yaw / compass / heading output very unrepeatable.
There is a fusion mode called 'NDOF_FMC_OFF' (0b00001011) which is the same as the BrickIMUV2.SENSOR_FUSION_ON mode but has the auto calibration routine for the magnetometer disabled.
You can still store a full calibration profile and all other functions are the same.  Using the same chip in an Arduino device has resulted in a more stable system without the unexplained 'jumps' in yaw output that are often seen in the NDOF mode
It looks like a simple enough change with no backward compatibility issues ?
Thanks for your consideration
I just released IMU Brick V2 firmware 2.0.13 with the new parameter. Call set_sensor_fusion_mode with 3. The new constant will be available with the next Bindings release.
Changes:
https://github.com/Tinkerforge/imu-v2-brick/commit/cb5d24238a7e403ba1cb981c574e093d63176ebd
https://github.com/Tinkerforge/imu-v2-brick/commit/2d1e81f59339a4ea83eb09d3fe3dbc0a8b822366
https://github.com/Tinkerforge/generators/commit/f4f2a0d3b1660fb45aaf19d65b9bf1a51a7dfbe9
I tested with this small script and played around in Brick Viewer. I think i can see the difference between the two modes.
#!/usr/bin/env python
# -*- coding: utf-8 -*-
HOST = "localhost"
PORT = 4223
UID = "6xEivJ" # Change to your UID
from tinkerforge.brick_imu_v2 import BrickIMUV2
if __name__ == "__main__":
    imu = BrickIMUV2(UID, ipcon) # Create device object
    imu.set_sensor_fusion_mode(3)
    print(imu.get_sensor_fusion_mode())
