JPannetier Geschrieben July 15, 2018 at 11:00 Geschrieben July 15, 2018 at 11:00 Hello , I'm using Python 3.6. I can run the example to emunerate my device. When I'm using example_simple.py from IMU brick 2.0. I have an error message from imu.get_quaternion() in get_quaternion return GetQuaternion(*self.ipcon.send_request(self, BrickIMU.FUNCTION_GET_QUATERNION, (), '', 'f f f f')) File "C:\Users\JPannetier\Anaconda3\lib\site-packages\tinkerforge\ip_connection.py", line 1194, in send_request return unpack_payload(response[8:], form_ret) File "C:\Users\JPannetier\Anaconda3\lib\site-packages\tinkerforge\ip_connection.py", line 251, in unpack_payload x = struct.unpack(f, data[:length]) error: unpack requires a buffer of 4 bytes Thank you Best regard Zitieren
photron Geschrieben July 16, 2018 at 09:18 Geschrieben July 16, 2018 at 09:18 This isn't a Problem with Python 3.6. The Problem ist that you're using the IMU Brick (1.0) example with an IMU Brick 2.0. Try this example: https://www.tinkerforge.com/en/doc/Software/Bricks/IMUV2_Brick_Python.html#simple Zitieren
JPannetier Geschrieben July 16, 2018 at 10:08 Autor Geschrieben July 16, 2018 at 10:08 Hi Photron, Exactly. I have a IMU Brick 2.0. And I have this error when i'm using your example of IMU Brick 2.0.... Best regard Zitieren
borg Geschrieben July 16, 2018 at 12:21 Geschrieben July 16, 2018 at 12:21 But it says "BrickIMU.FUNCTION_GET_QUATERNION" in your pasted error message. It should be "BrickIMUV2". Are you sure you are not using the IMU 1.0 example? Zitieren
JPannetier Geschrieben July 17, 2018 at 09:50 Autor Geschrieben July 17, 2018 at 09:50 I'm using a Brick IMU 2.0 with its example : https://www.tinkerforge.com/en/doc/Software/Bricks/IMUV2_Brick_Python.html#simple When I opened the source of Brick IMU 2.0, i can notice : Into communication.c : void get_quaternion(const ComType com, const GetQuaternion *data) { GetQuaternionReturn gqr; gqr.header = data->header; gqr.header.length = sizeof(GetQuaternionReturn); gqr.x = sensor_data.qua_x; gqr.y = sensor_data.qua_y; gqr.z = sensor_data.qua_z; gqr.w = sensor_data.qua_w; send_blocking_with_timeout(&gqr, sizeof(GetQuaternionReturn), com); } And into communication.h typedef struct { MessageHeader header; int16_t w; int16_t x; int16_t y; int16_t z; } __attribute__((__packed__)) GetQuaternionReturn; Zitieren
borg Geschrieben July 17, 2018 at 10:04 Geschrieben July 17, 2018 at 10:04 The error message above comes from the IMU Brick 1.0 bindings. You can see it from the names and also because of the "f f f f", since the 1.0 IMU returned floats while the new one returns ints. Please download the example again from here https://www.tinkerforge.com/en/doc/Software/Bricks/IMUV2_Brick_Python.html#simple and try it again. Zitieren
JPannetier Geschrieben July 17, 2018 at 19:29 Autor Geschrieben July 17, 2018 at 19:29 Super, It's working now. Sorry for my mistake. Thank you very much for your support. Best regard Jérôme Zitieren
