SEENIVASAGAM Geschrieben April 27, 2018 at 07:09 Geschrieben April 27, 2018 at 07:09 I want to use one stepper brick for 32 stepper motor with Ethernet port. Is possible OR if I request the Tinkerforge will customize based on our requirement. I do not understand the usage of master brick and extensions in stepper brick. Kindly clarify me? Zitieren
borg Geschrieben April 27, 2018 at 08:30 Geschrieben April 27, 2018 at 08:30 You have to build a stack out of Master Brick + Stepper Brick + Ethernet Extension to get a Stepper Brick that you can control via Ethernet. Zitieren
SEENIVASAGAM Geschrieben April 27, 2018 at 09:07 Autor Geschrieben April 27, 2018 at 09:07 Thank you so much admin. How can we use multiple stepper motor with this stepper bricks?? Zitieren
borg Geschrieben April 27, 2018 at 09:09 Geschrieben April 27, 2018 at 09:09 One Stepper Brick can only control one stepper motor. Zitieren
SEENIVASAGAM Geschrieben April 27, 2018 at 09:12 Autor Geschrieben April 27, 2018 at 09:12 OK Thank you for your guidance and suppport Zitieren
