luzik Geschrieben November 13, 2017 at 22:34 Geschrieben November 13, 2017 at 22:34 I've got simple rs232 app. My requires is to run it under both - touchscreen via RED brick, and on PC via usb. It is possible to use multiple instances of brickd? In the future i want to use wifi too control from android. Or maybe i should starting to write some kind of my own API for control app on RED brick ? Zitieren
borg Geschrieben November 14, 2017 at 08:31 Geschrieben November 14, 2017 at 08:31 You can connect the RED Brick to your PC via USB and run programs on your RED Brick and on your PC at the same time. That should just work. Zitieren
luzik Geschrieben November 15, 2017 at 20:06 Autor Geschrieben November 15, 2017 at 20:06 Can I use any of RED brick USB ports in otg mode (acting as serial or Ethernet on PC) ? Zitieren
borg Geschrieben November 15, 2017 at 22:15 Geschrieben November 15, 2017 at 22:15 The mini USB port by default shows up as two endpoints on your PC. One custom endpoint for the Tinkerforge Protocol and one serial port endpoint. Zitieren
