xsherlock Geschrieben October 25, 2017 at 14:01 Geschrieben October 25, 2017 at 14:01 I get a very strange openhab 2.1-stable error. I tried to add a 0-20mA sensor but it did not work as it should. I edited tinkerforge.cfg. I did a workarounf with python script to get this data. I removed all 4 lines I added to thinkerforge.cfg Now all my tinkerforge devices stopped to work. I get this error. 2017-10-25 15:50:04.294 [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=295, bundle=182/mvn:org.openhab.binding/org.openhab.binding.tinkerforge/1.10.0]: Updating property uid: CqV subId: sensor1 of configuration org.openhab.tinkerforge caused a problem: CONFIG: duplicate device config for uid "CqV" and subId "sensor1": fix openhab.cfg org.osgi.service.cm.ConfigurationException: uid: CqV subId: sensor1 : CONFIG: duplicate device config for uid "CqV" and subId "sensor1": fix openhab.cfg at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.fillupConfig(ConfigurationHandler.java:777)[182:org.openhab.binding.tinkerforge:1.10.0] at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.createOHTFDeviceConfig(ConfigurationHandler.java:397)[182:org.openhab.binding.tinkerforge:1.10.0] at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.createConfig(ConfigurationHandler.java:220)[182:org.openhab.binding.tinkerforge:1.10.0] at org.openhab.binding.tinkerforge.internal.TinkerforgeBinding.updated(TinkerforgeBinding.java:891)[182:org.openhab.binding.tinkerforge:1.10.0] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[3:org.apache.felix.configadmin:1.8.12] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[3:org.apache.felix.configadmin:1.8.12] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[3:org.apache.felix.configadmin:1.8.12] at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1772)[3:org.apache.felix.configadmin:1.8.12] at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:141)[3:org.apache.felix.configadmin:1.8.12] at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:109)[3:org.apache.felix.configadmin:1.8.12] at java.lang.Thread.run(Thread.java:745)[:1.8.0_121] First in 2.x there is no more openhab.cfg so I guess it is referring the tinkerforge.cfg but any references to CqV are gone from the file. Where is it cached? Restarting and rebooting does not help. I cant switch a single light in the house now. Zitieren
photron Geschrieben October 27, 2017 at 14:29 Geschrieben October 27, 2017 at 14:29 Assuming you're running Linux the config file should be here now, according to the openHAB2 documentation: /etc/openhab2/services/tinkerforge.cfg But the legacy support might also pickup the old openhab.cfg here: /etc/openhab2/services/openhab.cfg Zitieren
theo Geschrieben November 5, 2017 at 20:27 Geschrieben November 5, 2017 at 20:27 You will find some configuration examples here: https://github.com/theoweiss/openhab2-tinkerforge-configuration-examples Zitieren
xsherlock Geschrieben November 6, 2017 at 12:12 Autor Geschrieben November 6, 2017 at 12:12 As I wrote in the other post reverting the file /etc/openhab2/services/tinkerforge.cfg does not help Also in 2.1 clean instal there is no openhab.cfg any more. It was annoying in 2.0 but with strict validation in 2.1 if you make an error and it gets cached you have to reinstal OH as it stops to load the tinkerforge binding. Zitieren
