Gunther Geschrieben August 25, 2017 at 07:42 Geschrieben August 25, 2017 at 07:42 Nachdem ich den Kernel auf 4.12.5 upgedated habe startet brickd nicht mehr. Woran kann das liegen? Ich habe libusb neu installiert. # brickd --debug usb 2017-08-25 09:36:33.137827 <I> <main_linux.c:284> Brick Daemon 2.3.0 started (pid: 11616, daemonized: 0) 2017-08-25 09:36:33.137969 <W> <log.c:104> Unexpected char 'u' in debug filter 'usb' at index 0 2017-08-25 09:36:33.138085 <D> <event.c:57> Initializing event subsystem 2017-08-25 09:36:33.138215 <D> <event|event.c:221> Added generic event source (handle: 5, events: 0x0001) at index 0 2017-08-25 09:36:33.138304 <D> <hardware.c:39> Initializing hardware subsystem 2017-08-25 09:36:33.138368 <D> <usb.c:238> Initializing USB subsystem [timestamp] [threadID] facility level [function call] <message> -------------------------------------------------------------------------------- [ 0.000033] [00002d60] libusb: debug [libusb_init] created default context [ 0.000207] [00002d60] libusb: debug [libusb_init] libusb v1.0.19.10903 [ 0.000650] [00002d60] libusb: error [op_init] could not find usbfs 2017-08-25 09:36:33.139180 <E> <usb.c:430> Could not initialize libusb context: LIBUSB_ERROR_OTHER (-99) 2017-08-25 09:36:33.139304 <D> <hardware.c:53> Shutting down hardware subsystem 2017-08-25 09:36:33.139381 <D> <event|event.c:354> Marked generic event source (handle: 5, events: 0x0001) as removed at index 0 2017-08-25 09:36:33.139475 <D> <event.c:81> Shutting down event subsystem 2017-08-25 09:36:33.139558 <D> <event|event.c:372> Removed generic event source (handle: 5, events: 0x0001) at index 0 2017-08-25 09:36:33.139624 <I> <main_linux.c:450> Brick Daemon 2.3.0 stopped Zitieren
borg Geschrieben August 25, 2017 at 09:43 Geschrieben August 25, 2017 at 09:43 Laut der Fehlermeldung fehlt das usbfs. kannst du mal dmesg | grep usbfs ausführen? Es sollte sowas wie [ 0.187862] usbcore: registered new interface driver usbfs ausgegeben werden. Zitieren
