DrWino Geschrieben July 7, 2017 at 13:10 Geschrieben July 7, 2017 at 13:10 I purchased spacer mounting kits with my brick but they are too short. The spacing between the brick boards is 12.5mm but the spacers are 10 mm ! I kno it is only a few euro but a waste. Zitieren
borg Geschrieben July 7, 2017 at 15:07 Geschrieben July 7, 2017 at 15:07 If you purchased the 12mm mounting kit there are two kinds of spacers in there: One has one thread inside and one thread outside, the other has both threads inside. The 12mm mounting kit has 4 12mm inside/outside spacers and 4 10mm inside/inside spacers in it. You can put the 10mm spacer at the bottom and screw the 12mm spacer in the top. The small plastic washers can be used inbetween to fill the small gap. Like here: Or did you purchase the 9mm mounting kits? They can't be used for the Bricks! Zitieren
DrWino Geschrieben July 9, 2017 at 03:11 Autor Geschrieben July 9, 2017 at 03:11 Sorry. All the 8 spacers in the 2 kits are 10mm. I purchased them along with the bricks on the same webpage. In any event I found 12mm spacers in my workshop so no problem but you should fix this for other customers. Zitieren
borg Geschrieben July 9, 2017 at 09:26 Geschrieben July 9, 2017 at 09:26 The inside/inside thread spacers are allways 10. The inside/outside thread spacers are either 9mm or 12mm. There are no 10mm inside/outside thread spacers. Zitieren
DrWino Geschrieben July 9, 2017 at 14:52 Autor Geschrieben July 9, 2017 at 14:52 Look - it kind of silly to argue with a customer over a 1 euro part but you are wrong. I have attached a photo of the kit as it cam. Also you can see that the hex section of the spacers is the same - regardless of M/F or F/F. The length is 10 mm. Next to it I show my spacers which has a hex section length of 12mm. It fits the bricks correctly. Zitieren
borg Geschrieben July 9, 2017 at 15:04 Geschrieben July 9, 2017 at 15:04 Also you can see that the hex section of the spacers is the same - regardless of M/F or F/F. The length is 10 mm. No, the M/F is 1mm smaller than the F/F. You got a 9mm mounting kit: https://www.tinkerforge.com/en/shop/accessories/mounting/mounting-kit-9mm.html If you ordered them as 12mm mounting kits there must have been a mixup during packaging. Sorry! Please write an email to info@tinkerforge.com with your order number. We will of course send you the the 12mm mounting kits. Zitieren
