potato101 Geschrieben May 30, 2017 at 12:13 Geschrieben May 30, 2017 at 12:13 Hello! I would need to use bricklet cables that are longer than 2 meters. Is there any way I could extend them with an adapter or connector male to male? If so, where can I get them? If not, is it possible to get some custom cable made? I would need cables that are 5 meters long. Thanks for your help! Regards Zitieren
borg Geschrieben May 30, 2017 at 21:48 Geschrieben May 30, 2017 at 21:48 We do not recommend to go above 2m length for the Bricklet cables. For long cable runs you can use the RS485 Extension. For cables longer than 2m we can't guarantee signal integrity, we also do EMI tests only with the standard 6-200cm cables. That being said, you can of course cut one of our cables in the middle and extend it with other wires. The connectors and crimp contacts are also available in our shop. Zitieren
