I have been having a lot of problems getting the Ethernet Extensions to work reliable when used together. My test configuration consists of 3 master bricks, 2 Ethernet Extensions, 1 Raspberry Pi running brickd and a Windows PC running C#. The Windows PC is running the latest C# bindings and code very much from the Rugged Approach tutorial (full code at end).
TEST 1: Connecting to any IPConnection individually (by commenting out the Connect command for the other two) works very reliably and takes consistently about 0.05s.
TEST 2: Connecting to the Raspberry Pi and any one Ethernet Extension work equally reliably, and also takes about 0.05s to connect.
TEST 3: Connecting to the Raspberry Pi, one of the stacks to my Windows PC running a local brickd and USB connection (changing _HOST to be 127.0.0.1) and any one Master Extension work equally reliably as TEST 2.
TEST 4: Connecting to the Raspberry Pi and two Ethernet Extensions works only roughly 65% of the time (though somewhat oddly often takes 9.06s). When it fails it seems to consistently fail with the last stack to be called (i.e. if I change the order that the _TFStack.Connect commands are called it is the last one which will fail).
Please find my code below, note that that there is a Authenticate command at the end and _HOST which will have to be adjusted for your setup (and I know the code is not particularly clean, just hacked together for testing purposes).
Has anyone else had any problems connecting to multiple Ethernet Extensions?
using Tinkerforge;
using System.Diagnostics;
public class EthernetMasterTesting
    private const string _HOST1 = "192.168.1.1";
    private const string _HOST2 = "192.168.1.2";
    private const string _HOST3 = "192.168.1.3";
    private const int _PORT = 4223;
    private static IPConnection _TFStack1 = null;
    private static IPConnection _TFStack2 = null;
    private static IPConnection _TFStack3 = null;
    static void Main()
        long totalTime = 0;
        int numberOfTests = 5;
        for (int i = 0; i < numberOfTests; i++)
            if (_TFStack1 == null)
                _TFStack1 = new IPConnection();
                _TFStack1.Connected += ConnectedCB;
                _TFStack1.Disconnected += DisconnectedCB;
                _TFStack1.EnumerateCallback += EnumerateCB1;
            if (_TFStack2 == null)
                _TFStack2 = new IPConnection();
                _TFStack2.Connected += ConnectedCB;
                _TFStack2.Disconnected += DisconnectedCB;
                _TFStack2.EnumerateCallback += EnumerateCB2;
            if (_TFStack3 == null)
                _TFStack3 = new IPConnection();
                _TFStack3.Connected += ConnectedCB;
                _TFStack3.Disconnected += DisconnectedCB;
                _TFStack3.EnumerateCallback += EnumerateCB3;
            System.Console.WriteLine("Connect Requested");
            Stopwatch sw = new Stopwatch();
            sw.Start();
            try
                _TFStack1.Connect(_HOST1, _PORT);
            catch (System.Exception e)
                System.Console.WriteLine("Could not connect 1");
                System.Console.WriteLine(e.Source + " : " + e.Message);
            try
                _TFStack2.Connect(_HOST2, _PORT);
                System.Console.WriteLine("Could not connect 2");
            try
                _TFStack3.Connect(_HOST3, _PORT);
                System.Console.WriteLine("Could not connect 3");
            sw.Stop();
            System.Console.WriteLine("Took " + sw.ElapsedMilliseconds / 1000.0 + "s to connect stacks.");
            totalTime += sw.ElapsedMilliseconds;
            System.Threading.Thread.Sleep(1000);
            if (_TFStack1.GetConnectionState() == IPConnection.CONNECTION_STATE_CONNECTED)
                _TFStack1.Disconnect();
            if (_TFStack2.GetConnectionState() == IPConnection.CONNECTION_STATE_CONNECTED)
                _TFStack2.Disconnect();
            if (_TFStack3.GetConnectionState() == IPConnection.CONNECTION_STATE_CONNECTED)
                _TFStack3.Disconnect();
        System.Console.WriteLine("Average Time to connect stacks " + totalTime / (numberOfTests * 1000.0));
        System.Console.WriteLine("Press enter to exit");
        System.Console.ReadLine();
    private static void EnumerateCB3(IPConnection sender, string uid, string connectedUid, char position, short[] hardwareVersion, short[] firmwareVersion, int deviceIdentifier, short enumerationType)
        if (enumerationType == IPConnection.ENUMERATION_TYPE_CONNECTED ||
           enumerationType == IPConnection.ENUMERATION_TYPE_AVAILABLE)
            if (deviceIdentifier == BrickMaster.DEVICE_IDENTIFIER)
                System.Console.WriteLine("Brick connected " + uid + " on Stack 3");
    private static void EnumerateCB2(IPConnection sender, string uid, string connectedUid, char position, short[] hardwareVersion, short[] firmwareVersion, int deviceIdentifier, short enumerationType)
                System.Console.WriteLine("Brick connected " + uid + " on Stack 2");
    static void EnumerateCB1(IPConnection sender, string UID, string connectedUID,
                System.Console.WriteLine("Brick connected " + UID + " on Stack 1");
    private static void DisconnectedCB(IPConnection sender, short disconnectReason)
        System.Console.WriteLine("Disconnected");
    static void ConnectedCB(IPConnection sender, short connectReason)
        try
            sender.Authenticate("SUPERSECRETPASSWORD");
            sender.Enumerate();
            System.Console.WriteLine("After connected failed to authenticate or enumerate");
Thank you for the test code, i will try it out next Tuesday (don't have the time today and there is a holiday tomorrow and next Monday in Germany).
From looking at the code, it should definitely work without any delays!
I did not realise I had to manually set the MAC address on each Ethernet Extension based on the sticker under the Ethernet socker. Now that the MAC addresses have been set, TEST 4 works perfectly with a 0.05s average time to connect.
You shouldn't need to set the MAC addresses. They should come pre-configured with the MAC address that is on the sticker.
We even pay for the addresses to get them properly from IEEE.
Do all Ethernet Extensions that you own have the same address or only two that you had? I can only imagine that there was some kind error during our initial testing/flashing setup and we accidentally  wrote the same address to two extensions.
Oh, that is not good. That could mean that we had a problem during a whole batch. I will pick some Ethernet Extension from our stock at random and read the MAC address. If i find one with MAC address 40:D8:55:02:A0:00 we will probably have to re-configure all of them :o.
Thank you for the hint and sorry for the problems!
Hello.
That was very interesting news. I had for a while ago almost the same problem.
I had two Master Brick's, each with a Ethernet module. Each of them had a separate IP-address. No problems to connect to stack 1 or two, it was running good. But starting both the stack's, with two separate Python programs, impossible.
My first idea then was, "I have done some configuration error". Anyhow, there was no time for faultfinding, so i made another solution to solve my problem then. Now I understand why it didn't work ...
After I was reading your last reply's, I took out the 2 Ethernet modules I had in my "spare" boxes.
When testing both of them with Brick Viewer, both of them where showing the same MAC address as you mentioned, (40:D8:55:02:A0:00), not as printed on the labels.
One of these modules was ordered in middle Jan -17, the other one in Febr. -17
// Göran P
Not sure what happend there :(.
Our OUI/company id is 40:D8:55 with one assigned address block of 02:A0:00 to 02:AF:FF.
So obviously something went wrong during our automated configuration process if at least 4 Ethernet Extension have the starting address assigned. I have to assume that a whole batch (250pcs) wasn't given a proper MAC address.
As far as i can tell at the moment, all but 29 Ethernet Extensions of that batch have already been sold...
Edit: I checked all of the Ethernet Extensions and all of the ones we have in stock have the correct MAC address.
@GoranP, I am glad to hear I was not the only one with this problem, I immediately assumed it was something I was doing wrong with my code...
@borg I don't know when you generated the images on your website, but the automated configuration process might have been having issues longer than you think. The MAC address for the screenshot on
https://www.tinkerforge.com/en/doc/Hardware/Master_Extensions/Ethernet_Extension.html#ethernet-configuration has the same 02:A0:00 ending.
Hi...i am a new user here. In my case i had two Master Brick's, each with a Ethernet module. Each of them had a separate IP-address. No problems to connect to stack 1 or two, it was running good. But starting both the stack's, with two separate Python programs, impossible.
turnkey pcb
@LulaNord: Do your Ethernet Extensions have the same MAC address too (02:A0:00 in the end)?
I am still confused about this problem. I found that if you reset the EEPROM the configuration of the Ethernet Extension defaults to the 02:A0:00 MAC address.
You can reset the EEPROM with the Brick Viewer in the Master Brick Tab through the "Configure Extension Type" popup. If you set type to Ethernet it will write a default Ethernet configuration to the EEPROM which has this MAC address.
This is meant for cases where a configuration has become completely broken or if the EEPROM for some reason looses a configuration and the Extension can not be discovered anymore (the type of extension is stored in the EEPROM too).
We need to document this feature better, it is probably completely unclear for most users what this "Configure Extension Type" feature does.
Did any of you reset the EEPROM with this by any chance?
