87yj Geschrieben April 7, 2017 at 00:25 Share Geschrieben April 7, 2017 at 00:25 Hello All - I just purchased an IMU 2.0 brick and am trying to use Brick Viewer to connect to it. My setup is Windows 10, USB cable connection to the brick. When starting Brick V, it does not appear to detect the brick. Also tried using a Raspberry pi, same results. I'm at a loss for troubleshooting and understanding what's happening and I haven't found any help in the doc. Can someone help with a pointer on how to figure out if the brick is working / connecting and how to communicate? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben April 7, 2017 at 07:36 Share Geschrieben April 7, 2017 at 07:36 Did you also install Brick Daemon? Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
87yj Geschrieben April 8, 2017 at 15:17 Autor Share Geschrieben April 8, 2017 at 15:17 Yes. I finally figured it out...bad USB cable. switched cables and it works like a charm. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
