I am attempting to compile the C# bindings in a Ubuntu 16.0 environment using mono compiler version Stable 4.8.0.495/e4a3cf3.
Reverting to csharp-2.1.12 git tag and running the following commands:
cd ~/tf/generators/csharp
python generate_csharp_bindings.py && python generate_csharp_zip.py
I receive the following xbuild compile errors:
Project "/tmp/generator/csharp/source/Tinkerforge/Tinkerforge.csproj" (default target(s)):
Target PrepareForBuild:
	Configuration: Release Platform: AnyCPU
	Created directory "bin/Release/"
	Created directory "obj/Release/"
Target ResolveNuGetPackageAssets:
: error : Your project is not referencing the ".NETFramework,Version=v4.0" framework. Add a reference to ".NETFramework,Version=v4.0" in the "frameworks" section of your project.json, and then re-run NuGet restore.
Task "ResolveNuGetPackageAssets" execution -- FAILED
Done building target "ResolveNuGetPackageAssets" in project "/tmp/generator/csharp/source/Tinkerforge/Tinkerforge.csproj".-- FAILED
Done building project "/tmp/generator/csharp/source/Tinkerforge/Tinkerforge.csproj".-- FAILED
Build FAILED.
Errors:
/tmp/generator/csharp/source/Tinkerforge/Tinkerforge.csproj (default targets) ->
/usr/lib/mono/xbuild/Microsoft/NuGet/Microsoft.NuGet.targets (ResolveNuGetPackageAssets target) ->
 0 Warning(s)
 1 Error(s)
I assumed the issue was with the project.json requesting invalid dependencies, though that all looks as fairly minimal and correct. Doing some research it seems that the project.lock.json file is generated anyway by the project.json file so I thought I would try simply deleting it, and it now compiles fine. The easiest way I found to remove it was to delete line 77 from generate_csharp_zip.py as well as deleting the file.
Is the project.lock.json actually required?
Further to this I have just tried to compile tag csharp-2.1.10 which does not include the json files and works perfectly, it is only in 2.1.11 and 2.1.12 where I have the compile problems.
Oh, I didn't notice that recent Mono picks up those project.json files as well. They are only meant for Visual Studio.
You can just delete them on Linux for now.
I'll look into a correct solution for this problem. Thanks for the report.
