Bottesford Geschrieben January 5, 2017 at 13:45 Geschrieben January 5, 2017 at 13:45 I was wondering if there was a way to disable any of the status LEDs found on the various bricks & bricklets? I'm using the wifi extension + motion detector bricklet which between them have 3 bright LEDs. These are useful in testing but for the motion detector especially it is undesirable having the bright blue light on every time someone walks in the room. I intend to set it up in a bedroom (for automatic switch on of lighting at suitable times) so a bright LED in the middle of the night isn't nice. Also I'm considering the power use of all these LEDs running all the time - it would be better to disable them when not testing the system. Is the any plan to add some a method 'SetStatusLightsOff' or similar? Zitieren
borg Geschrieben January 9, 2017 at 09:12 Geschrieben January 9, 2017 at 09:12 For the Master Brick there is a disable_wifi2_status_led() as well as a disable_status_led() function. For the Motion Detector Bricklet we currently don't have such an API. I will write in on my TODO list, adding this API is not a huge amount of work. edit: Translated to English, accidentally answered in German . Zitieren
Bottesford Geschrieben January 9, 2017 at 22:16 Autor Geschrieben January 9, 2017 at 22:16 Thank you, very helpful! Zitieren
borg Geschrieben January 9, 2017 at 23:01 Geschrieben January 9, 2017 at 23:01 I already added the API in the Motion Detector source code, will be available with the next Bindings release. https://github.com/Tinkerforge/motion-detector-bricklet/commit/f327f00f01dafd6a01bc4bc704b49e686aea94bb Zitieren
Bottesford Geschrieben January 21, 2017 at 17:19 Autor Geschrieben January 21, 2017 at 17:19 When will the updated c# DLL be ready so I can use this in my code? My bricklet was updated but I still can't use the new method yet. Thanks. Zitieren
borg Geschrieben January 25, 2017 at 09:48 Geschrieben January 25, 2017 at 09:48 We just made a new Bindings release, so the new function is now available in C# . Zitieren
Bottesford Geschrieben January 26, 2017 at 20:41 Autor Geschrieben January 26, 2017 at 20:41 Thanks but I'm getting : System.MissingMethodException : Method not found: 'Void Tinkerforge.BrickletMotionDetector.SetStatusLEDConfig(Byte)'. I call it like this: bricklet.SetStatusLEDConfig(BrickletMotionDetector.STATUS_LED_CONFIG_OFF); I'm using the latest bindings (2.1.12.0) and I have fully updated all my Bricks & Bricklets as well as Brickd and viewer. Zitieren
borg Geschrieben January 27, 2017 at 08:52 Geschrieben January 27, 2017 at 08:52 You have to update the firmware on your Bricklet, it does not now the method yet. Zitieren
