techniker Geschrieben October 23, 2016 at 19:16 Geschrieben October 23, 2016 at 19:16 Hallo Zusammen Ich möchte mir gerne eine aktuelle offline Doku erstellen, aber das Ausführen des generate_all.py endet immer mit folgenden Fehler. Auch in einem osboxes-image Ubuntu 15.10 habe ich die gleichen Meldungen. gus@CF-20:~/tf/generators$ python2 generate_all.py Generating bindings for c: * brick_dc * brick_imu * brick_imu_v2 * brick_master * brick_red * brick_servo * brick_silent_stepper (not released, not documented) Traceback (most recent call last): File "generate_all.py", line 33, in <module> module.generate(os.path.join(path, binding)) File "/home/gus/tf/generators/c/generate_c_bindings.py", line 798, in generate common.generate(bindings_root_directory, 'en', CBindingsGenerator) File "/home/gus/tf/generators/common.py", line 743, in generate generator.generate(device) File "/home/gus/tf/generators/c/generate_c_bindings.py", line 790, in generate h.write(device.get_c_header()) File "/home/gus/tf/generators/c/generate_c_bindings.py", line 632, in get_c_header header += self.get_c_function_declaration() File "/home/gus/tf/generators/c/generate_c_bindings.py", line 586, in get_c_function_declaration doc = packet.get_c_formatted_doc() File "/home/gus/tf/generators/c/generate_c_bindings.py", line 669, in get_c_formatted_doc text = self.get_device().specialize_c_doc_function_links(text) File "/home/gus/tf/generators/c/generate_c_bindings.py", line 44, in specialize_c_doc_function_links return self.specialize_doc_function_links(text, specializer) File "/home/gus/tf/generators/common.py", line 1410, in specialize_doc_function_links raise Exception('Unknown :func: found: ' + m.group(1)) Exception: Unknown :func: found: :func:`SetStallguardCoolstepConfiguration` Zitieren
borg Geschrieben October 24, 2016 at 08:28 Geschrieben October 24, 2016 at 08:28 Oh, da war in der Tat ein Typo in den configs committet. Hab das gefixt, bitte einmal "git pull" im "tf/generator/" Verzeichnis aufrufen. Danach geht es dann. Zitieren
techniker Geschrieben October 25, 2016 at 16:20 Autor Geschrieben October 25, 2016 at 16:20 Vielen Dank, leider treten noch ein paar Probleme auf. am Ende vom generate_all.py * bricklet_voltage_current Traceback (most recent call last): File "generate_all.py", line 72, in <module> run_zip_generator(path, binding) File "generate_all.py", line 63, in run_zip_generator module.generate(os.path.join(path, binding)) File "/home/gus/tf/generators/csharp/generate_csharp_zip.py", line 125, in generate common.generate(bindings_root_directory, 'en', CSharpZipGenerator) File "/home/gus/tf/generators/common.py", line 745, in generate generator.finish() File "/home/gus/tf/generators/csharp/generate_csharp_zip.py", line 110, in finish os.path.join(self.tmp_source_tinkerforge_dir, 'Tinkerforge.csproj')]) File "/home/gus/tf/generators/common.py", line 620, in execute if subprocess.call(args, **kwargs) != 0: File "/usr/lib/python2.7/subprocess.py", line 523, in call return Popen(*popenargs, **kwargs).wait() File "/usr/lib/python2.7/subprocess.py", line 711, in __init__ errread, errwrite) File "/usr/lib/python2.7/subprocess.py", line 1343, in _execute_child raise child_exception OSError: [Errno 2] No such file or directory und dann beim ausführen des copy_all.py gus@CF-20:~/tf/generators$ sudo python2 copy_all.py [sudo] Passwort für gus: Copying ip_connection to brickv: Copying Python bindings to brickv: Copying 'en' documentation and examples: Copying 'de' documentation and examples: Copying Tinkerforge.js to doc/en: Traceback (most recent call last): File "copy_all.py", line 122, in <module> shutil.copy(src_file, dest_dir) File "/usr/lib/python2.7/shutil.py", line 119, in copy copyfile(src, dst) File "/usr/lib/python2.7/shutil.py", line 82, in copyfile with open(src, 'rb') as fsrc: IOError: [Errno 2] No such file or directory: '/home/gus/tf/generators/javascript/Tinkerforge.js' Zitieren
photron Geschrieben October 26, 2016 at 08:02 Geschrieben October 26, 2016 at 08:02 Es sieht aus als ob dir xbuild fehlt. Das kommt aus dem mono-xbuild Package, das Teil von mono-complete sein sollte. mono-complete sollte allerdings vom Build Environment Script installiert worden sein. Versuch mal das manual nachzuinstallieren: sudo apt-get install mono-xbuild Zitieren
techniker Geschrieben October 28, 2016 at 17:09 Autor Geschrieben October 28, 2016 at 17:09 Besten Dank, jetzt habe ich den Fehler gefunden. im build_environment_setup.sh das php5 Paket konnte im Ubuntu 16.10 Yakkety nicht installiert werden, darum wurde die ganze apt-get Zeile nicht ausgeführt. Somit fehlte xbuild und alles andere aus dieser Anweisung. Leider habe ich die mono 2.0 Files nicht nachinstallieren können. Hab jetzt die von der mono 4.5 benutzt und es funktioniert. # Packages for "generators/generate_all.py" sudo apt-get -y install build-essential mono-complete python3 perl default-jre default-jdk nodejs npm php5 php-pear ruby zip sudo npm install -g browserify sudo ln -s /usr/bin/nodejs /usr/local/bin/node Zitieren
photron Geschrieben November 2, 2016 at 08:58 Geschrieben November 2, 2016 at 08:58 Ah, Ubuntu hat das Package von php5 in php umbenannt. Das Setup Skript sollte jetzt damit umgehen können. Zitieren
