Code for two stepper bricks does not work. Can anybody help?
Following is a VB code for 2 stepper bricklets.  The hardware works with the example shown on the Tinkerforge homepage.  Can anybody tell me why this my code does not work and what I have to change? The 3 error messages from Visual Basic are shown at the end of the code.
The code is for a two axis measuring tool to move the table.
Thank you!
Best,
Harry
Code for Reed Measuring Device
OUTLINE
​Module MeasureReed
Reset device position​
WaitForStart()
For x = 35 to 71 by 1
  ​For y = -9 to 9 by 1
​​MoveDeviceTo(x,y)
​    ​MeasureReed()
        ​Output measurement
​Next y
​​Move Excel cursor back up and to right
Next x
​End Module
Visual Basic Code
Imports System
Imports Tinkerforge
Module MeasureAltoReed
  Const HOST As String = "localhost"
  Const PORT As Integer = 4223
  Const UIDx As String = "5W5E6E"    ' Change XXYYZZ to the UID of your x direction Stepper Brick
  Const UIDy As String = "67PGPm "    ' Change XXYYZZ to the UID of your y direction Stepper Brick
  Sub Main()
      Dim ipconx As New IPConnection()                        ' Create IP connection for x
​ Dim ipcony As New IPConnection()                        ' Create IP connection for y
      Dim stepperx As New BrickStepper(UIDx, ipconx)  ' Create device object for x direction stepper
      Dim steppery As New BrickStepper(UIDy, ipcony)  ' Create device object for y direction stepper
      ipcon.Connect(HOST, PORT) ' Connect to brickd Don't use device before ipcon is connected
      stepperx.SetSpeedRamping(30000, 30000)    '    Set stepper x values
      stepperx.SetMexVelocity(5000)
      stepperx.StepDecay(50000)
      stepperx.Enable()                                              '  Enable x motor power
      stepperx.SetStepMode(4)
      steppery.SetSpeedRamping(30000, 30000)    '    Set stepper y values
      steppery.SetMexVelocity(5000)
      steppery.StepDecay(50000)
      steppery.Enable()                                              '  Enable y motor power
      steppery.SetStepMode(4)
      Console.WriteLine("Press key to start")
      Console.ReadLine()
      Dim currentxpos As Integer = 0
      Dim currentypos As Integer = 82
      Dim distancexaway As Integer
      Dim distanceyaway As Integer
​ distancexaway = -9 – currentxpos      ​‘ Move to (-9,35) from start (0,82)
stepperx.SetSteps(distancexaway*800)    ‘ 800 steps = 1 mm
currentxpos = currentxpos + distancexaway
distanceyaway = 35 – currentypos
steppery.SetSteps(distanceyaway*800)
​ currentypos = currentypos + distanceyaway
      For x As Integer = -9 To 9
          distancexaway = x - currentxpos
          For y As Integer = 35 To 73
              distanceyaway = y - currentypos
          ​  steppery.SetSteps(distanceyaway*800)
              Console.WriteLine("Current position ( x , y ) (" + x.ToString() + ", " + y.ToString() + ")")
              ' Get reed measurement and output
          Next y
      Next x
      stepperx.Disable()
      steppery.Disable()
      ipcon.Disconnect()
  End Sub
End Module
Severity
Code
Description
Project
File
Line
Suppression State
Error
BC30002
Type 'IPConnection' is not defined.
MeasuringTollCorr.4
c:\users\boss\documents\visual studio 2015\Projects\MeasuringTollCorr.4\MeasuringTollCorr.4\Module1.vb
13
Active
Error
BC30002
Type 'BrickStepper' is not defined.
MeasuringTollCorr.4
14
Active
Error
BC30002
MeasuringTollCorr.4
15
Active
ReplyQuoteNotify
