Python 3.2.3/Win7/64Bit -> ez_setup.py gives an error message
I installed Phyton 3.2.3 64Bit/win7 and tried to install the .egg files using setuptools 0.6c11 / ez_setup.py. On the Python page it says
"64-bit versions of Python
    Download ez_setup.py and run it; it will download the appropriate .egg file and install it for you. (Currently, the provided .exe installer does not support 64-bit versions of Python for Windows, due to a distutils installer compatibility issue"
I copied the ez_setup.py to the Python32 folder and started the script, but it gives an error in line 111. Do I miss something? Or doesn't it support 3.2.3?
I'm new to Python and decided to use 3.2.3 to make a clear cut with 2.7.
Any idea how to get the egg file 'installed'.
Thank you for your help.
So how to install the tinkerforge.egg? xD
it doesn´t run with the easy_install function.....
it says:
SyntaxError: unexpected character after line continuation character
Am I have to add a line end character?
