is there guidance available on how to use the TinkerForge Javascript Bindings in Node-RED.
Have tried to define a simple call to an ambilight bricklet in a Node-RED function, but received error 31=timeout.
//var Tinkerforge = require('/usr/lib/node_modules/tinkerforge');
var Tinkerforge = context.global.tinkerforge;
var HOST = '192.168.0.88';
var PORT = 4223;
var UID = 'mdh';
var ipcon = new Tinkerforge.IPConnection();
var al = new Tinkerforge.BrickletAmbientLight(UID, ipcon);
ipcon.connect(HOST, PORT,
    function (error) {
        node.warn('Connect Error: ' + error);
ipcon.on(Tinkerforge.IPConnection.CALLBACK_CONNECTED,
    function (connectReason) {
        al.getIlluminance(
            function (illuminance) {
                msg.payload = "{\"Illuminance\":" + illuminance/10.0 + "}";
                node.warn('Illuminance: ' + illuminance/10.0 + ' Lux');
            function (error) {
                msg.payload = "{\"lluminance\":" + error + "}";
                node.warn('Get Error: ' + error);
ipcon.disconnect();
return msg;
Note: defined in node-red settings, after installing tinkerforge via npm:
    functionGlobalContext: {
    		tinkerforge:require('/usr/lib/node_modules/tinkerforge')
Solved by using the MQTT proxy as broker on localhost:1883.
Defined a simple test flow with:
  • Input Node "MQTT In" subscribing to topic "tinkerforge/bricklet/ambient_light/mdh/illuminance"
  • Function Node JSON to convert MQTT string to javascript object
  • Function Node Function to log the payload properties illuminance and _timestamp
  • Debug Node to log the MQTT payload (which is a JSON string)
Looks promising to explore further integration of TinkerForge in Node-RED.
UPDATE
Installed:
$sudo npm install -g tinkerforge
Added to NODE_PATH:
$export NODE_PATH=$NODE_PATH:/usr/local/lib/node_modules
Installed:
$npm install body-parser in the .node-red folder under node_modules
Created folder:
/home/pi/.node-red/node_modules/node-red-contrib-tinkerforge
Copied the lib folder and other files to node-red-contrib-tinkerforge
Started node-red
TinkerForge nodes available
COOL
Added the ambientlight (v1) sensor by amending lib/bricklets.js, tinkerforge.js & tinkerforge.html.
Again Thanks a Lot = Job Well Done
It's not been packaged for npm just yet
but you can npm install direct from github with the following:
npm install hardillb/node-red-contrib-tinkerforge
If you run this in /home/pi/.node-red it will end up in the right place
I have only done a Ambient light v2.0 node as that's the only hardware I have available to test. But it should be pretty simple do v1.0 node if somebody can let me know the deviceIdentifier.
  • 3 months later...
I have brickd running on a Pi with a Master Brick and Analogue Out v2 connect on port D connected by USB. I am trying to control from Node Red and have installed node-red-contrib-tinkerforge. Brickviewer on the Pi can detect the master and analogue bricklet and can adjust the output correctly, so brickd seems to be working. Node red Analogue out node detects the Analogue node id correctly but does not change the output. The config is localhost:4223 which is the same as Brickviewer on the Pi. Any suggestions would be appreciated
Hi...i am a new user here. I think you can npm install direct from github with the following:npm install hardillb/node-red-contrib-tinkerforge
If you run this in /home/pi/.node-red it will end up in the right place.I have only done a Ambient light v2.0 node as that's the only hardware I have available to test. But it should be pretty simple do v1.0 node if somebody can let me know the device Identifier.
printed circuit board assembly
