hardillb Geschrieben June 14, 2016 at 12:03 Share Geschrieben June 14, 2016 at 12:03 Can anybody point me at some examples of using a RS485 Brick with a RED Brick? Specifically I was looking for examples of connecting to none Tinkerforge modbus devices Thanks Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
hardillb Geschrieben June 14, 2016 at 12:59 Autor Share Geschrieben June 14, 2016 at 12:59 Having read the description again more closely I now assume that the RS485 extension can only be used to communicate with other RS485 Extensions to combine stacks. If I want to talk to 3rd party RS485 Modbus kit then I'll have to use a USB RS485 adapter on a RED Brick and a separate bus. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
borg Geschrieben June 15, 2016 at 11:41 Share Geschrieben June 15, 2016 at 11:41 Yes, using a USB RS485 is definitely easier then to try to write your own code for the RS485 Extension ! Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
