Austin71 Geschrieben May 16, 2016 at 17:33 Geschrieben May 16, 2016 at 17:33 I am creating a C++/MFC program to run the stepper motor. I have included "ws2_32.lib" and "advapi32.lib" in the project properties (linker additional dependencies). I am using the following defines: #define HOST "localhost" #define PORT 4223 #define UID "5W5jBJ" // Obtained from running brick viewer I am using the following code, taken from the example code: // Create IP connection IPConnection ipcon; ipcon_create(&ipcon); // Create device object Stepper stepper; stepper_create(&stepper, UID, &ipcon); // Connect to brickd if (ipcon_connect(&ipcon, HOST, PORT) < 0) { //returns -4 } Everything compiles fine, but I can't connect. I have loaded the brickd drivers for the stepper motor, and I can connect and run the stepper motor using brick viewer. Any clues as to what I may be doing wrong? Thanks. Zitieren
photron Geschrieben May 17, 2016 at 08:10 Geschrieben May 17, 2016 at 08:10 The modified version of ip_connection.c I gave you can resolve "localhost" to its IPv6 address, but brickd doesn't bind to an IPv6 address by default. To make ip_connection.c resolve "localhost" to its IPv4 address you need to replace AF_UNSPEC with AF_INET in your ip_connection.c. Zitieren
Austin71 Geschrieben May 17, 2016 at 20:05 Autor Geschrieben May 17, 2016 at 20:05 Can I ask a follow up question? Your suggestion worked and we are now able to run the stepper motor. However, when execution of the following test block is finished, I have memory leaks. Obviously, this block doesn't do anything except connect and release, but I wanted to isolate the memory leak problem: --------------------- IPConnection ipcon; ipcon_create(&ipcon); Stepper stepper; stepper_create(&stepper, UID, &ipcon); stepper_disable(&stepper); ipcon_destroy(&ipcon); --------------------- My output windows shows: Detected memory leaks! Dumping objects -> {586} normal block at 0x006E50C0, 4248 bytes long. Data: < 5 6n > 01 00 00 00 20 35 F6 C0 E0 36 6E 00 02 00 00 CD Object dump complete. Thank you for any advice. Zitieren
photron Geschrieben May 18, 2016 at 08:21 Geschrieben May 18, 2016 at 08:21 The code does more than connect and release. You're calling stepper_disable which disables the stepper motor driver. You should call stepper_destroy instead. The memory leak comes from not calling stepper_destroy. It seems that these destroy calls are missing in all our C/C++ examples. I'm going to fix that now. Zitieren
Austin71 Geschrieben May 18, 2016 at 15:35 Autor Geschrieben May 18, 2016 at 15:35 Fantastic, thanks very much. I thought the disable instruction was not enough, and I even looked for a destroy command but somehow missed it. My fault. All's well now and we are off and running. At least until the next question! Zitieren
