potato101 Geschrieben May 10, 2016 at 12:48 Geschrieben May 10, 2016 at 12:48 Hi everyone, I would like to be able to see and control my HDMI 12.7cm display directly from my microsoft windows computer. e.g. : with remote desktop connection (RDP). Thanks for your help Zitieren
borg Geschrieben May 10, 2016 at 15:57 Geschrieben May 10, 2016 at 15:57 Where is the HDMI display connected? To the RED Brick? Or to a Windows machine? Zitieren
potato101 Geschrieben May 10, 2016 at 16:24 Autor Geschrieben May 10, 2016 at 16:24 Hi, the HDMI cable goes from the RED brick to an HDMI display. Thank you Zitieren
borg Geschrieben May 11, 2016 at 13:12 Geschrieben May 11, 2016 at 13:12 Then you will need to try to get a rdp server running on the RED Brick, for example http://www.xrdp.org. This is unfortunately not pre-installed on the standard RED Brick image. Zitieren
