rwblinn Geschrieben April 20, 2016 at 13:39 Geschrieben April 20, 2016 at 13:39 Is it possible to build a Stack with a Step Down Power Supply and 3 Master Bricks = MasterBrick 2.0 + Master Brick 2.1 + Master Brick 2.0? Just curious if the version difference of the Master Bricks will cause any issues? Zitieren
photron Geschrieben April 21, 2016 at 07:10 Geschrieben April 21, 2016 at 07:10 That works. All Master Brick hardware versions are compatible to each other. Zitieren
