kwally Geschrieben March 14, 2016 at 03:43 Geschrieben March 14, 2016 at 03:43 Could you confirm that the Red Brick negates the use of a Raspberry? Zitieren
Dimitrios Geschrieben March 14, 2016 at 08:48 Geschrieben March 14, 2016 at 08:48 Hi kwally, i have a Raspberry Pi 2B+, it works excellent with RED Brick, Zitieren
jgmischke Geschrieben March 14, 2016 at 11:08 Geschrieben March 14, 2016 at 11:08 Kwally --- no problems with Red Brick and Raspi 2. Can you explain your problem? Zitieren
derAngler Geschrieben March 14, 2016 at 14:34 Geschrieben March 14, 2016 at 14:34 I think he wants to know if a raspberry pi is necessary if u have a RED Brick. And the answer is no, you don't need a raspberry if u already have a RED Brick. Zitieren
Nic Geschrieben March 15, 2016 at 09:45 Geschrieben March 15, 2016 at 09:45 @kwally You asked this question exactly 1 year before: http://www.tinkerunity.org/forum/index.php/topic,3011.msg18840.html#msg18840 If you do NOT need a shield or any proprietary hardware build specially for the raspi then you can (most likely) exchange the raspi by the RED. Both runs a Debian distro and an ARM cpu. Depends which raspi do you have, the RED has slightly less performance/memory. At the RED there is a GPIO interface but I assume it will never be supported by drivers or adapters. TF has removed the description about it from documentation. A raspi has lots of GPIOs a better support of several interfaces e.g. I2C. On a RED you have to solve it by the wide range of existing bricklets. On a certain raspi you can have Ethernet and more USB connectors onboard. For the RED you need an ethernet extension and a USB hub. PS: Finally RED supports "only" a lower version (3.4) of the kernel in opposite to the rasp (4.1). Means some hardware connected to the RED could be not supported because of missing drivers in kernel. If you are an expert in Linux you can try to recompile the kernel with embedded drivers. But I think you cannot really compare a Rasp with the RED. For me the RED is more a super brick providing us a "ondevice programming" without any need of a desktop/host pc on very small form factor, smaller than the raspi. Zitieren
kwally Geschrieben March 24, 2016 at 04:17 Autor Geschrieben March 24, 2016 at 04:17 Thank you Der Angler, that is exactly what I wanted to know. I now need to educate myself re the Red Brick, and how one communicates and views information provided by it. Thank you all Karl Zitieren
