I'm using a Dual Analog In bricklet to measure some water flow.
The sensor I'm using requires DC 5V Power supply and reports
its value in a range of 0.5V to 3.5V.
So, I've connected the Bricklet to the flow device this way:
- 5.0V Output pin '+' to the 5V
- 5.0V Output pin '-' to Ground
- +/-35V Input 1 'pin 0' to flow analog signal
- +/-35V Input 1 'pin 1' to 5.0V Output pin '-'
This allows me to get some value but it with some kind of offset (around 700mV)
regarding to the expected value.
According to the technical support's answer I got from the manufacturer of the device, I should connect the PE of the flow sensor to the equipment which is used to measure the signal of the device.
I'm not sure how I would do this (I guess it would be to the 5.0V Output pin '-' to Ground), so any advise would be welcome.
Thanks in advance for your help.
Regards.
