REd brick openHAB MQTT usage
rwblinn
as a test tried to setup openHAB MQTT displaying AmbientLight bricklet Illuminance BUT nothing is displayed. Any idea what could be wrong?
Items
Number Illuminance "Illuminance [%.0f Lux]" <none> { }
String IlluminanceRaw "IlluminanceRaw" [%s] <none> { mqtt="<[mosquitto:tinkerforge/bricklet/ambient_light/mdh/illuminance:state:default]" }
Rule
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
rule "MqttAmbientLightParse"
  when
    Item IlluminanceRaw changed
  then
var String json = (IlluminanceRaw.state as StringType).toString
logInfo("FILE", json)
//{"illuminance":1354,"_timestamp":1456750088.109141}
var String il = transform("JSONPATH", "$.illuminance", json)
logInfo("FILE", "IL="+il)
var String ts = transform("JSONPATH", "$._timestamp", json)
logInfo("FILE", "TS="+ts)
    	sendCommand(Illuminance,  il)
  end
sitemap
sitemap ambientlightmqtt label="MQTT Illuminance"
Frame
	Text item=Illuminance
	Text item=IlluminanceRaw
By...
Items
String IlluminanceTimeStamp "Illuminance Timestamp [%1$tm/%1$td %1$tH:%1$tM]" <none>
String IlluminanceRaw "IlluminanceRaw [%s]" <none> { mqtt="<[mosquitto:tinkerforge/bricklet/ambient_light/mdh/illuminance:state:default]" }
Sitemap
Frame
	Text item=IlluminanceTimeStamp
Rules = UNIX timestamp conversion needs to be improved.
import org.joda.time.*
when
then
//Convert the raw data to a string
var String data = (IlluminanceRaw.state as StringType).toString
//Parse the JSON string
// { "illuminance":1354,"_timestamp":1456750088.109141 }
//Illuminance
var String il = transform("JSONPATH", "$.illuminance", data)
var iln = new Double(il)
iln = iln * 0.1
    	Illuminance.postUpdate( iln)
//Timestamp
var String ts = transform("JSONPATH", "$._timestamp", data)
        //THIS NEEDS TOBE IMPROVED
ts = ts.replaceAll("E9", "")
ts = ts.replaceAll("[.]", "")
//IlluminanceTimeStamp.postUpdate(ts)
var DateTime dt = new DateTime(Long::parseLong(ts) * 1000L)
IlluminanceTimeStamp.postUpdate(new DateTimeType(dt.toString))
end
