rwblinn Geschrieben February 18, 2016 at 18:34 Geschrieben February 18, 2016 at 18:34 Hi, connected a LED to A0 of the IO16 bricklet. Using the Brick Viewer and setting the Port Direction to Output, the LED can be turned on and off via changing the value Low to High vv. Tried to setup the same by using openHAB, but the LED is not reacting. Any hints what is worng in below openHAB Testconfiguration having Port A0 as output outa0? #openhab.cfg tinkerforge:hosts=127.0.0.1 tinkerforge:io16.uid=gkM tinkerforge:io16.type=bricklet_io16 tinkerforge:io16.debouncePeriod=100 tinkerforge:io16outa0.uid=gkM tinkerforge:io16outa0.subid=outa0 tinkerforge:io16outa0.type=io_actuator tinkerforge:io16outa0.defaultState=true #items Number TF_AmbientLight "Luminance [%.0f lx]" { tinkerforge="uid=mdh" } Switch outa0 "LED A0" { tinkerforge="uid=gkM, subid=outa0" } #rules import org.openhab.core.library.types.* rule "LED Switch" when Item outa0 changed then if (outa0.state == true) sendcommand(outa0, false) else sendcommand(outa0, true) end NOTE: Instead of true false also tried ON OFF. #sitemap sitemap tf_weather_station label="Weather Station" { Frame { Text item=TF_AmbientLight Switch item=outa0 } } Zitieren
rwblinn Geschrieben February 20, 2016 at 08:53 Autor Geschrieben February 20, 2016 at 08:53 Removed the rule "LED Switch". Switching the LED connected to the IO16 Bricklet Port A0 is working fine. Zitieren
