generator and brickboot make error
wolf84
Hi
run generator script error? to deal with it?
LD brickd
-- The C compiler identification is GNU 4.8.3
-- The CXX compiler identification is GNU 4.8.3
-- Check for working C compiler: /usr/bin/arm-none-eabi-gcc
-- Check for working C compiler: /usr/bin/arm-none-eabi-gcc -- broken
CMake Error at /usr/share/cmake-3.0/Modules/CMakeTestCCompiler.cmake:61 (message):
  The C compiler "/usr/bin/arm-none-eabi-gcc" is not able to compile a simple
  test program.
  It fails with the following output:
  Change Dir: /home/osboxes/tf/master-brick/software/build/CMakeFiles/CMakeTmp
  Run Build Command:"/usr/bin/make" "cmTryCompileExec3743751674/fast"
  /usr/bin/make -f CMakeFiles/cmTryCompileExec3743751674.dir/build.make
  make[1]: Entering directory
  '/home/osboxes/tf/master-brick/software/build/CMakeFiles/CMakeTmp'
  /usr/bin/cmake -E cmake_progress_report
  /home/osboxes/tf/master-brick/software/build/CMakeFiles/CMakeTmp/CMakeFiles
  1
  Building C object
  CMakeFiles/cmTryCompileExec3743751674.dir/testCCompiler.c.obj
  /usr/bin/arm-none-eabi-gcc -o
  CMakeFiles/cmTryCompileExec3743751674.dir/testCCompiler.c.obj -c
  /home/osboxes/tf/master-brick/software/build/CMakeFiles/CMakeTmp/testCCompiler.c
  Linking C executable cmTryCompileExec3743751674
  /usr/bin/cmake -E cmake_link_script
  CMakeFiles/cmTryCompileExec3743751674.dir/link.txt --verbose=1
  CMakeFiles/cmTryCompileExec3743751674.dir/testCCompiler.c.obj -o
  /usr/lib/gcc/arm-none-eabi/4.8/../../../arm-none-eabi/lib/libc.a(lib_a-exit.o):
  In function `exit':
  /build/buildd/newlib-2.1.0+git20140818.1a8323b/build/arm-none-eabi/newlib/libc/stdlib/../../../../../newlib/libc/stdlib/exit.c:70:
  undefined reference to `_exit'
  collect2: error: ld returned 1 exit status
  CMakeFiles/cmTryCompileExec3743751674.dir/build.make:88: recipe for target
  'cmTryCompileExec3743751674' failed
  make[1]: Leaving directory
  make[1]: *** [cmTryCompileExec3743751674] Error 1
  Makefile:118: recipe for target 'cmTryCompileExec3743751674/fast' failed
  make: *** [cmTryCompileExec3743751674/fast] Error 1
  CMake will not be able to correctly generate this project.
Call Stack (most recent call first):
  CMakeLists.txt:6 (PROJECT)
-- Configuring incomplete, errors occurred!
See also "/home/osboxes/tf/master-brick/software/build/CMakeFiles/CMakeOutput.log".
See also "/home/osboxes/tf/master-brick/software/build/CMakeFiles/CMakeError.log".
Linking C executable master-brick.elf
  text   data     bss     dec     hex filename
126896       0   6012 132908   2072c master-brick.elf
[100%] Built target master-brick.elf
  test program.
  Change Dir: /home/osboxes/tf/temperature-bricklet/software/build/CMakeFiles/CMakeTmp
  Run Build Command:"/usr/bin/make" "cmTryCompileExec2720114032/fast"
  /usr/bin/make -f CMakeFiles/cmTryCompileExec2720114032.dir/build.make
  '/home/osboxes/tf/temperature-bricklet/software/build/CMakeFiles/CMakeTmp'
  /home/osboxes/tf/temperature-bricklet/software/build/CMakeFiles/CMakeTmp/CMakeFiles
  1
  Building C object
  CMakeFiles/cmTryCompileExec2720114032.dir/testCCompiler.c.obj
  CMakeFiles/cmTryCompileExec2720114032.dir/testCCompiler.c.obj -c
  /home/osboxes/tf/temperature-bricklet/software/build/CMakeFiles/CMakeTmp/testCCompiler.c
  Linking C executable cmTryCompileExec2720114032
  CMakeFiles/cmTryCompileExec2720114032.dir/link.txt --verbose=1
  CMakeFiles/cmTryCompileExec2720114032.dir/testCCompiler.c.obj -o
  In function `exit':
  CMakeFiles/cmTryCompileExec2720114032.dir/build.make:88: recipe for target
  'cmTryCompileExec2720114032' failed
  make[1]: *** [cmTryCompileExec2720114032] Error 1
  Makefile:118: recipe for target 'cmTryCompileExec2720114032/fast' failed
  make: *** [cmTryCompileExec2720114032/fast] Error 2
  CMakeLists.txt:7 (PROJECT)
See also "/home/osboxes/tf/temperature-bricklet/software/build/CMakeFiles/CMakeOutput.log".
See also "/home/osboxes/tf/temperature-bricklet/software/build/CMakeFiles/CMakeError.log
brickboot not complied
cp -avr ~/tf/bricklib ~/tf/brickboot/software/src
cd ~/tf/brickboot/software
./generate_makefile
  test program.
  Change Dir: /home/osboxes/tf/brickboot/software/build/CMakeFiles/CMakeTmp
  Run Build Command:"/usr/bin/make" "cmTryCompileExec619403037/fast"
  /usr/bin/make -f CMakeFiles/cmTryCompileExec619403037.dir/build.make
  '/home/osboxes/tf/brickboot/software/build/CMakeFiles/CMakeTmp'
  /home/osboxes/tf/brickboot/software/build/CMakeFiles/CMakeTmp/CMakeFiles 1
  Building C object
  CMakeFiles/cmTryCompileExec619403037.dir/testCCompiler.c.obj
  CMakeFiles/cmTryCompileExec619403037.dir/testCCompiler.c.obj -c
  /home/osboxes/tf/brickboot/software/build/CMakeFiles/CMakeTmp/testCCompiler.c
  Linking C executable cmTryCompileExec619403037
  CMakeFiles/cmTryCompileExec619403037.dir/link.txt --verbose=1
  CMakeFiles/cmTryCompileExec619403037.dir/testCCompiler.c.obj -o
  In function `exit':
  CMakeFiles/cmTryCompileExec619403037.dir/build.make:88: recipe for target
  'cmTryCompileExec619403037' failed
  make[1]: *** [cmTryCompileExec619403037] Error 1
  Makefile:118: recipe for target 'cmTryCompileExec619403037/fast' failed
  make: *** [cmTryCompileExec619403037/fast] Error 2
See also "/home/osboxes/tf/brickboot/software/build/CMakeFiles/CMakeOutput.log".
See also "/home/osboxes/tf/brickboot/software/build/CMakeFiles/CMakeError.log".
First of all, you don't need brickboot, it's obsolete.
It seems that you're not using the latest master-brick.git content. Please check that your
~/tf/master-brick/software/generate_makefile
looks like this
#!/bin/bash
mkdir -p build
cmake -E chdir build/ cmake -DCMAKE_TOOLCHAIN_FILE=../src/bricklib/toolchains/arm-none-eabi.cmake ../
# Because of a bug in cmake we have to call it two times... For the second
# execution the toolchain files are already defined
cmake -E chdir build/ cmake ../
Now delete this directory
~/tf/master-brick/software/build/
and run generate_makefile again:
cd ~/tf/master-brick/software/
./generate_makefile
It runs cmake twice. The first run is expected to fail, the second should succeed like this:
-- The C compiler identification is GNU 4.9.3
-- The CXX compiler identification is GNU 4.9.3
-- Check for working C compiler: /home/matthias/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc
-- Check for working C compiler: /home/matthias/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc -- broken
CMake Error at /usr/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:61 (message):
  The C compiler
  "/home/matthias/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc" is not
  able to compile a simple test program.
   Change Dir: /home/matthias/tf/dev/master-brick/software/build/CMakeFiles/CMakeTmp
  Run Build Command:/usr/bin/make "cmTryCompileExec1785423513/fast"
  /usr/bin/make -f CMakeFiles/cmTryCompileExec1785423513.dir/build.make
  make[1]: Verzeichnis
  »/home/matthias/tf/dev/master-brick/software/build/CMakeFiles/CMakeTmp«
  wird betreten
  /home/matthias/tf/dev/master-brick/software/build/CMakeFiles/CMakeTmp/CMakeFiles
  1
  Building C object
  CMakeFiles/cmTryCompileExec1785423513.dir/testCCompiler.c.obj
  /home/matthias/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc -o
  CMakeFiles/cmTryCompileExec1785423513.dir/testCCompiler.c.obj -c
  /home/matthias/tf/dev/master-brick/software/build/CMakeFiles/CMakeTmp/testCCompiler.c
  Linking C executable cmTryCompileExec1785423513
  CMakeFiles/cmTryCompileExec1785423513.dir/link.txt --verbose=1
  CMakeFiles/cmTryCompileExec1785423513.dir/testCCompiler.c.obj -o
  /home/matthias/gcc-arm-none-eabi-4_9-2015q2/bin/../lib/gcc/arm-none-eabi/4.9.3/../../../../arm-none-eabi/lib/libc.a(lib_a-exit.o):
  In function `exit':
  exit.c:(.text.exit+0x2c): undefined reference to `_exit'
  make[1]: *** [cmTryCompileExec1785423513] Fehler 1
  wird verlassen
  make: *** [cmTryCompileExec1785423513/fast] Fehler 2
See also "/home/matthias/tf/dev/master-brick/software/build/CMakeFiles/CMakeOutput.log".
See also "/home/matthias/tf/dev/master-brick/software/build/CMakeFiles/CMakeError.log".
-- Check for working C compiler: /home/matthias/gcc-arm-none-eabi-4_9-2015q2/bin/arm-none-eabi-gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
Found following source files:
/home/matthias/tf/dev/master-brick/software/src/communication.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/logging/logging.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/crc/crc.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/dacc/dacc.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/pwmc/pwmc.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usart/uart_console.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usart/usart.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/twi/twid.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/twi/twi.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/adc/adc.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/pio/pio.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/pio/pio_it.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/efc/efc.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/wdt/wdt.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/flash/flashd.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/board/board_cstartup_gnu.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/board/board_lowlevel.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/board/exceptions.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/tc/tc.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usb/USBD.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usb/USBDescriptors.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usb/USBRequests.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usb/USBDCallbacks.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usb/USBD_HAL.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usb/USBDDriver.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/usb/USBDDriverCallbacks.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/pmc/pmc.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/spi/spi.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/drivers/uid/uid.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/free_rtos/croutine.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/free_rtos/tasks.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/free_rtos/portable/MemMang/heap_tf.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/free_rtos/portable/GCC/ARM_CM3/port.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/free_rtos/queue.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/free_rtos/list.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/pearson_hash.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/rand.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/init.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/led.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/syscalls.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/profiling.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/trace.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/sqrt.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/mutex.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/sha_1.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/utility/base64_encode.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/com_messages.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/i2c/i2c_eeprom/i2c_eeprom_common.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/i2c/i2c_eeprom/i2c_eeprom_slave.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/i2c/i2c_eeprom/i2c_eeprom_master.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/none/none.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/com.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/usb/usb_descriptors.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/usb/usb_callbacks.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/usb/usb.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/com_common.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/i2c/i2c_clear_bus.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/bricklet/bricklet_communication.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/bricklet/bricklet_init.c;/home/matthias/tf/dev/master-brick/software/src/extensions/extension_init.c;/home/matthias/tf/dev/master-brick/software/src/extensions/extension_i2c.c;/home/matthias/tf/dev/master-brick/software/src/extensions/brickd.c;/home/matthias/tf/dev/master-brick/software/src/extensions/websocket.c;/home/matthias/tf/dev/master-brick/software/src/extensions/chibi/chibi_low_level.c;/home/matthias/tf/dev/master-brick/software/src/extensions/chibi/chibi_master.c;/home/matthias/tf/dev/master-brick/software/src/extensions/chibi/chibi_slave.c;/home/matthias/tf/dev/master-brick/software/src/extensions/chibi/chibi_init.c;/home/matthias/tf/dev/master-brick/software/src/extensions/chibi/chibi.c;/home/matthias/tf/dev/master-brick/software/src/extensions/rs485/rs485_low_level.c;/home/matthias/tf/dev/master-brick/software/src/extensions/rs485/rs485_slave.c;/home/matthias/tf/dev/master-brick/software/src/extensions/rs485/rs485_master.c;/home/matthias/tf/dev/master-brick/software/src/extensions/rs485/rs485.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi/wifi_low_level.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi/wifi_command.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi/wifi_data.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi/wifi_ringbuffer.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi/wifi.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi2/wifi2.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi2/wifi2_uart.c;/home/matthias/tf/dev/master-brick/software/src/extensions/wifi2/wifi2_bootloader.c;/home/matthias/tf/dev/master-brick/software/src/extensions/ethernet/ethernet_websocket.c;/home/matthias/tf/dev/master-brick/software/src/extensions/ethernet/ethernet_low_level.c;/home/matthias/tf/dev/master-brick/software/src/extensions/ethernet/ethernet_dhcp.c;/home/matthias/tf/dev/master-brick/software/src/extensions/ethernet/ethernet.c;/home/matthias/tf/dev/master-brick/software/src/extensions/ethernet/ethernet_w5200.c;/home/matthias/tf/dev/master-brick/software/src/extensions/ethernet/ethernet_w5500.c;/home/matthias/tf/dev/master-brick/software/src/main.c;/home/matthias/tf/dev/master-brick/software/src/master.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/spi/spi_stack/spi_stack_select_dma.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/spi/spi_stack/spi_stack_common_dma.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/spi/spi_stack/spi_stack_slave_dma.c;/home/matthias/tf/dev/master-brick/software/src/bricklib/com/spi/spi_stack/spi_stack_master_dma.c;/home/matthias/tf/dev/master-brick/software/src/routing_dma.c
-- Configuring done
-- Generating done
-- Build files have been written to: /home/matthias/tf/dev/master-brick/software/build
Now you can run make
cd cd ~/tf/master-brick/software/build/
make
