hallo !
habe rs485-netzwerk mit stepdown von 26v in jeder node :
( red + ethernet-ext + rs485-ext) <---> (1-3 master-bricks + rs-485) <---> ....
... <---> (1-3 master-bricks + rs-485)
der red ist eine eigene node damit der stromverbrauch des usb-gsm-dongles & der ethernet-extension nicht zu instabilitäten führt
PROBLEM(E):
1) der brick "stirbt" mit folgenden system-log-einträgen "send verification failed" - SIEHE :
  Zitat
2016-01-13 17:27:29.542519 <I> <network.c:373> Added new client (N: 192.168.1.40:60875, T: plain-socket, H: 26, A: disabled)
2016-01-13 17:27:34.211817 <I> <client.c:220> Client (N: 192.168.1.40:60875, T: plain-socket, H: 26, A: disabled) disconnected by peer
2016-01-13 17:27:34.211991 <W> <client.c:381> Destroying client (N: 192.168.1.40:60875, T: plain-socket, H: 26, A: disabled) while 1 request(s) are still pending
2016-01-13 17:27:35.212141 <W> <zombie.c:96> Destroying zombie (id: 5) while 1 request(s) are still pending
2016-01-13 17:27:36.248623 <I> <network.c:373> Added new client (N: 192.168.1.40:60877, T: plain-socket, H: 26, A: disabled)
2016-01-13 17:27:42.809263 <I> <client.c:220> Client (N: 127.0.0.1:49521, T: plain-socket, H: 25, A: disabled) disconnected by peer
2016-01-13 17:27:46.856486 <I> <network.c:373> Added new client (N: 127.0.0.1:49522, T: plain-socket, H: 25, A: disabled)
2016-01-13 17:28:13.881132 <I> <client.c:220> Client (N: 127.0.0.1:49522, T: plain-socket, H: 25, A: disabled) disconnected by peer
2016-01-13 17:28:19.897407 <I> <client.c:220> Client (N: 192.168.1.40:60877, T: plain-socket, H: 26, A: disabled) disconnected by peer
2016-01-13 17:28:22.118107 <I> <network.c:373> Added new client (N: 192.168.1.40:60883, T: plain-socket, H: 25, A: disabled)
2016-01-13 17:28:26.080620 <I> <network.c:373> Added new client (N: 127.0.0.1:49523, T: plain-socket, H: 26, A: disabled)
2016-01-13 17:28:44.106513 <I> <client.c:220> Client (N: 127.0.0.1:49523, T: plain-socket, H: 26, A: disabled) disconnected by peer
2016-01-13 17:29:32.533394 <I> <client.c:220> Client (N: 192.168.1.40:60883, T: plain-socket, H: 25, A: disabled) disconnected by peer
2016-01-13 17:29:32.533780 <W> <client.c:381> Destroying client (N: 192.168.1.40:60883, T: plain-socket, H: 25, A: disabled) while 1 request(s) are still pending
2016-01-13 17:29:33.533987 <W> <zombie.c:96> Destroying zombie (id: 6) while 1 request(s) are still pending
2016-01-13 23:58:05.188141 <E> <red_rs485_extension.c:370> Send verification failed
2016-01-13 23:58:05.202755 <E> <red_rs485_extension.c:370> Send verification failed
2016-01-14 01:48:03.064621 <E> <red_rs485_extension.c:370> Send verification failed
2016-01-14 01:48:03.078639 <E> <red_rs485_extension.c:370> Send verification failed
ethernet funktioniert auch nicht mehr obwohl die grüne led brav blinkt & wenn ich über den mini-usb an die serielle console will um nachzusehen, so höre die leds auf zu blinken und das wars ...
die einzige forschungsmöglichkeit ist nachträglich das log anzusehen ;-((
startup sieht in etwa so aus :
  Zitat
2016-01-16 20:18:05.473927 <I> <main_linux.c:281> Brick Daemon 2.2.1~hf2+redbrick started (daemonized)
2016-01-16 20:18:07.166600 <I> <red_extension.c:598> Found Ethernet Extension at position 0
2016-01-16 20:18:07.663515 <I> <red_stack.c:531> SPI stack slave discovery done. Found 0 slave(s) with 0 UID(s) in total
2016-01-16 20:18:14.882619 <I> <red_extension.c:584> Found RS485 Extension at position 1
2016-01-16 20:18:14.882813 <I> <red_rs485_extension.c:904> Initializing extension subsystem
2016-01-16 20:18:14.883174 <I> <red_rs485_extension.c:304> Baudrate configured = 50000, Effective baudrate = 50000.000000
2016-01-16 20:18:14.883370 <I> <red_rs485_extension.c:333> Serial interface initialized
2016-01-16 20:18:14.883408 <I> <red_rs485_extension.c:647> Initialized RS485 RXE state
2016-01-16 20:18:14.883497 <I> <red_rs485_extension.c:998> Initialized as master
2016-01-16 20:18:14.896523 <I> <redapid.c:309> Connected to RED Brick API Daemon
2016-01-16 20:18:14.896882 <I> <red_stack.c:552> Starting reinitialization of SPI slaves
2) generell (auch wenn der obige fehler noch nicht aufgetreten ist) gibt es ein problem über usb von windows-7 aus über den mini-usb an die serielle console hernazukommen :
das gerät wird nicht erkannt & im devicemanager verbleibt ein unerkanntes gerät
neuinstallation vom brickviewer/brickdaemon am windows-7 hat (noch) nicht geholfen ...
was kann ich da nun tun ?
lg
w
UPDATE :
habe fast einen tag verbracht mit forschen und bin auf die glorreiche idee gekommen, den red-brick (und auch die rs485-extension) zu tauschen ...
bei dem ersatz-red-brick funktioniert die serielle schnittstelle sobald die led auf grün blinkend geht --> ersuche um rma auf dem kurzen wege bei meiner nächsten bestellung !!!
ob ein offensichtlicher hardwaredefekt am red die ursache des send_verification-problems war werde ich beobachten müssen ...
ich werde das hier berichten .....
lgw
danke für den prompten tausch !!!
bis jetzt gibt es keine "brösel" am ersatz-red.
hoffe das bleibt so ....
aber vielleicht sollte ich den defekten doch zurücksenden und man könnte dann das noch untersuchen -
vielleicht liegen ein paar platinenverbindungen oder smd-bauteile arg nah an den befestigungslöchern - oder kann man sonst was mechanisch vermurksen ...
(n.b. ich will keine arbeit machen oder den zurückschicken und er landet dann doch in der rundablage ... aber ich finde das ganze doch sehr sehr seltsam)
lg
w
hab dmesg beim defekten red (serial console wird nicht mit usb_modeswitch geswitcht) mit dem ersatz-red verglichen :
  Zitat
[4 sekunden pause ]
[    8.871946] incomplete xfer (0x20)
  Zitat
[    5.272390] insmod_device_driver
[    5.272406] [sw_udc]: sw_usb_device_enable start
[    5.272415] [sw_udc]: usb_vbase  = 0xf1c13000
[    5.272424] [sw_udc]: sram_vbase = 0xf1c00000
[    5.272449] [sw_udc]: open_usb_clock
[    5.369673] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED
[    5.369696] [sw_udc]: usbd_start_work
[    5.369704] [sw_udc]: sw_usb_device_enable end
[    5.425154] [sw_udc]: IRQ: suspend
[    5.425181] [sw_udc]: ERR: usb speed is unkown
[    5.432366] usb 2-1: new high-speed USB device number 2 using sw-ehci
[    5.535214] [sw_udc]: IRQ: reset
[    5.535240] [sw_udc]: irq: reset happen, throw away all urb
[    5.583854] [sw_udc]:
[    5.583872] +++++++++++++++++++++++++++++++++++++
[    5.583879] [sw_udc]:  usb enter high speed.
[    5.583887] [sw_udc]:
[    5.583891] +++++++++++++++++++++++++++++++++++++
[    5.584103] [sw_udc]: Set address 4
[    5.604014] RED Brick gadget: high-speed config #1: foobar
[    5.604037] [sw_udc]: ep enable: ep1(0x80805c14, ep1-bulk, 128, 512)
[    5.604058] [sw_udc]: ep enable: ep2(0x80805c60, ep2-bulk, 0, 512)
[    5.604086] [sw_udc]: ep enable: ep5(0x80805d44, ep5-int, 128, 10)
[    5.604101] [sw_udc]: ep enable: ep3(0x80805cac, ep3-bulk, 128, 512)
[    5.604113] [sw_udc]: ep enable: ep4(0x80805cf8, ep4-bulk, 0, 512)
[    5.612877] scsi0 : usb-storage 2-1:1.0
[    6.613766] scsi 0:0:0:0: CD-ROM            HSPA    USB SCSI CD-ROM  2.31 PQ: 0 ANSI: 2
[    6.619439] sr0: scsi-1 drive
[    6.619463] cdrom: Uniform CD-ROM driver Revision: 3.20
[    6.619887] sr 0:0:0:0: Attached scsi CD-ROM sr0
[    7.702606] ehci_irq: port change detect
[    7.702709] usb 2-1: USB disconnect, device number 2
[    7.803043] ehci_irq: port change detect
[    8.102314] usb 2-1: new high-speed USB device number 3 using sw-ehci
[    8.739153] usbcore: registered new interface driver usbserial
[    8.739170] usbserial: USB Serial Driver core
[    8.799570] usbcore: registered new interface driver option
[    8.799885] USB Serial support registered for GSM modem (1-port)
[    8.800193] option 2-1:1.0: GSM modem (1-port) converter detected
[    8.810290] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[    8.810506] option 2-1:1.1: GSM modem (1-port) converter detected
[    8.812849] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[    8.813099] option 2-1:1.3: GSM modem (1-port) converter detected
[    8.815238] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[    9.953234] w5x00: 2.0.0
[    9.953300] w5x00 probe [int 17, rst 15, sel 0, mac 40:d8:55:2:a4:95]
[    9.953310] chip select before: 0
[  10.808661] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85500)
[  10.808688] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85880)
[  10.808701] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85640)
[  10.808712] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85680)
[  10.808724] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed856c0)
[  10.808735] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed854c0)
[  10.808749] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85000)
[  10.808760] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85800)
[  10.808773] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85700)
[  10.808785] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85740)
[  10.808797] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed857c0)
[  10.808809] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85840)
[  10.808821] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85980)
[  10.808832] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85940)
[  10.808844] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed859c0)
[  10.808855] [sw_udc]: alloc request: ep(0x80805cf8, ep4-bulk, 512), req(0x9ed85a00)
[  10.808867] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85a40)
[  10.808879] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85a80)
[  10.808890] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85ac0)
[  10.808902] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85b00)
[  10.808914] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85b40)
[  10.808926] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85b80)
[  10.808937] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85bc0)
[  10.808948] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85c00)
[  10.808960] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85c40)
[  10.808972] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85c80)
[  10.808984] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85cc0)
[  10.808995] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85d00)
[  10.809006] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85d40)
[  10.809018] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85d80)
[  10.809030] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85dc0)
[  10.809042] [sw_udc]: alloc request: ep(0x80805cac, ep3-bulk, 512), req(0x9ed85e00)
ohne dass ich jetzt einen kurs in sunxi udc machen muss - wie kann ich da noch weiter prüfen ???
lg
w
Mit usb_modeswitch hat das nicht zu tun. Der RED Brick ist ein USB Composite Device mit einem Vendor Specific Interface (Tinkerforge API) und einem CDC-ACM Interface (serielle Schnittstelle).
Der RED Brick sollte als zwei Devices im Geräte Manager auftauchen: "RED Brick" und "RED Brick Serial Console".
Taucht der problematische RED Brick nur als ein unbekanntes Gerät auf, oder taucht das "RED Brick" Gerät, aber das "RED Brick Serial Console" nicht auf?
Ich würde auf ersteres tippen, das würde zu einem Hardwäredefekt passen. Da kannst du softwaremäßig nichts machen und nichts debuggen.
Das zweite Log vom RED Brick sieht normal aus
... es taucht als unbekanntes gerät auf.
ich hab den red im übrigen jetzt entsorgt ;-)
danke für die mühen der ebene & lg
