rwblinn Geschrieben January 12, 2016 at 16:13 Geschrieben January 12, 2016 at 16:13 Hi, where to find the latest version of the Brick Viewer 2.3.3 for the Raspberry Pi? Wanted to use the new OLED 64x48 bricklet connected to the Raspberry Pi, but version brickv 2.3.0 states unknow device. Tried below to update, but still brickv 2.3.0: wget http://download.tinkerforge.com/tools/brickv/linux/brickv_linux_latest.deb sudo dpkg -i brickv_linux_latest.deb Zitieren
photron Geschrieben January 12, 2016 at 16:58 Geschrieben January 12, 2016 at 16:58 Does the current directory already contain a file named brickv_linux_latest.deb? In this case wget will not replace it but download the new file as brickv_linux_latest.deb.1. Zitieren
rwblinn Geschrieben January 12, 2016 at 18:41 Autor Geschrieben January 12, 2016 at 18:41 You're spot on. Good to know. Solved. Thanks for swift reply. Zitieren
