JavaLaurence Geschrieben December 26, 2015 at 11:19 Geschrieben December 26, 2015 at 11:19 Hi TF team, Would it be possible if you enhanced the API for the Segment Display bricklet so that we can a) put any integer in the range 0..9999 on the display in a single call (without having to mess with the segments individually) b) put any single-digit decimal in any of the 4 available slots, again, in a single call. Given that you must already have the code to control the segments to "render" digits (hidden within your counter API), I would imagine that adding the above is very little work. Thx! Laurence Zitieren
