photron Geschrieben November 4, 2015 at 15:56 Geschrieben November 4, 2015 at 15:56 While creating Brick Viewer 2.3.1 for Mac OS X, I noticed that the Data Logger dialog wont show up after clicking the "Data Logger" button. I need to click the "Updates / Flashing" button as well to make both dialogs show up. I tried to debug the problem, but with no success. I found that the problem only occurs if I start Brick Viewer from the Finder or the Application folder. But if I start it from a terminal like this /Applications/Brickv.app/Contents/MacOS/brickv then the problem is gone and the Data Logger dialog shows up immediately. Because the problem now also occurs with Brick Viewer 2.3.0, I believe that Brick Viewer itself is not directly at fault but the Mac OS X version (10.11 / El Captian) or our Macbook here has a problem. Could the Mac users out there test this and report if you have this problem as well? Zitieren
