I'm trying to run "matlab_example_callback.m" for BrickletVoltageCurrent.
When the example code "set(vc, 'PowerReachedCallback', @(h, e) cb_power_reached(e));" is executed MATLAB reports the following error:
java.lang.NullPointerException
at com.mathworks.jmi.bean.MatlabBeanInterface.addCallback(MatlabBeanInterface.java:484)
at com.mathworks.jmi.bean.MatlabCallbackInterface.addCallback(MatlabCallbackInterface.java:130)
If I type set(vc) there is no callback class listed to register...
Class: [1x1 java.lang.Class]
Configuration: [1x1 com.tinkerforge.BrickletVoltageCurrent$Configuration]
Current: 0
CurrentCallbackPeriod: 1000
CurrentCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$CurrentCallbackThreshold]
DebouncePeriod: 100
Identity: [1x1 com.tinkerforge.Device$Identity]
Power: 0
PowerCallbackPeriod: 0
PowerCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$PowerCallbackThreshold]
Voltage: 0
VoltageCallbackPeriod: 0
VoltageCallbackThreshold: [1x1 com.tinkerforge.BrickletVoltageCurrent$VoltageCallbackThreshold]
The example callback won't register. Does anyone have any ideas what could be wrong here?
Many thanks
I tested with this
function matlab_example_threshold()
    import com.tinkerforge.BrickletVoltageCurrent;
    ipcon = IPConnection(); % Create IP connection
    vc = BrickletVoltageCurrent('XYZ', ipcon); % Create device object
    set(vc)
end
and got this output
APIVersion
Class
Configuration
Current
DebouncePeriod
Identity
Power
PowerCallbackPeriod
ResponseExpectedAll: [ on | off ]
Voltage
PowerReachedCallback: string -or- function handle -or- cell array
VoltageReachedCallback: string -or- function handle -or- cell array
VoltageCallback: string -or- function handle -or- cell array
CurrentReachedCallback: string -or- function handle -or- cell array
CurrentCallback: string -or- function handle -or- cell array
PowerCallback: string -or- function handle -or- cell array
ButtonDownFcn: string -or- function handle -or- cell array
Children
Clipping: [ {on} | off ]
CreateFcn: string -or- function handle -or- cell array
DeleteFcn: string -or- function handle -or- cell array
BusyAction: [ {queue} | cancel ]
HandleVisibility: [ {on} | callback | off ]
HitTest: [ {on} | off ]
Interruptible: [ {on} | off ]
Parent
Selected: [ on | off ]
SelectionHighlight: [ {on} | off ]
Tag
UIContextMenu
UserData
Visible: [ {on} | off ]
Did you install the bindings according to the documentation?
http://www.tinkerforge.com/en/doc/Software/API_Bindings_MATLAB.html#matlab
Also make sure to use the Tinkerforge.jar from the MATLAB bindings zip file. The Tinkerforge.jar from the Java bindings will probably not work.
What MATLAB version are you using?
Hi photron
Thank you for responding. Something strange is happening for me.
I am using MATLAB 2015b and the Tinkerforge.jar file from the \MATLAB bindings directory (v2_0_5 file size: 980,064 bytes). In the MATLAB classpath.txt file I have this
# DO NOT MODIFY THIS FILE.  IT IS AN AUTOGENERATED FILE.
$<Lots of MATLAB Jar files added to the path>
$matlabroot/Tinkerforge.jar
If I execute your simple code I get this:
vc = BrickletVoltageCurrent(UID, ipcon); % Create device object
>> set(vc)
ans =
    CurrentCallbackPeriod: {}
           DebouncePeriod: {}
      PowerCallbackPeriod: {}
      ResponseExpectedAll: {}
    VoltageCallbackPeriod: {}
>> ipcon.connect(HOST, PORT); % Can't use get without executing this
>> get(vc)
                  APIVersion: [3x1 int16]
                     Current: 0
              DebouncePeriod: 100
                       Power: 0
                     Voltage: 0
>> ver
ver
MATLAB Version: 8.6.0.232648 (R2015b)
MATLAB License Number: xxxxxx
Operating System: Microsoft Windows 8.1 Version 6.3 (Build 9600)
Java Version: Java 1.7.0_60-b19 with Oracle Corporation Java HotSpot(TM) 64-Bit Server VM mixed mode
MATLAB                                                Version 8.6         (R2015b Prerelease)
Signal Processing Toolbox                             Version 7.1         (R2015b Prerelease)
Please can I ask what version of MATLAB you are using?
I tested with R2012a.
I think I found the problem. There's a change about how callbacks are handled in R2014a, see
http://undocumentedmatlab.com/blog/matlab-callbacks-for-java-events-in-r2014a
According to that blog post you need to replace
with
vc = handle(BrickletVoltageCurrent(UID, ipcon), 'CallbackProperties');
to expose callbacks again. Could you test that?
Fantastic Photron - problem solved,
Tinkerforge Callbacks are now established in MATLAB R2015b - Don't you just love undocumented features.
For completeness the following updated code now produces this output.
vc = handle(BrickletVoltageCurrent(UID, ipcon),'CallbackProperties');
>> set(vc)
ans =
            DebouncePeriod: {}
      PowerReachedCallback: {}
    VoltageReachedCallback: {}
           VoltageCallback: {}
    CurrentReachedCallback: {}
           CurrentCallback: {}
             PowerCallback: {}
My understanding is the listeners only report when a change is detected which means I can't check if the callback is actually executing until tomorrow when I can add a test load.
