Quellcode aus den Projekten von introducing
gibt es irgendwo die quelltexte von dem was im Introducing video gezeigt wurde?? Ich habe mir jetzt den Lautstärkeregla mit dem Linear Poti schon nachprogrammiert währe allerdings sehr an dem code des "Art" Projektes mit dem DistanceIR interessiert.
import com.tinkerforge.BrickletLinearPoti;
public class ExampleCallbackalsamixer {
private static final String host = new String("localhost");
private static final int port = 4223;
private static final String UID = new String("739"); // Change to your UID
// Note: To make the example code cleaner we do not handle exceptions. Exceptions you
//       might normally want to catch are described in the commnents below
public static void main(String args[]) throws Exception {
	// Create connection to brickd
	IPConnection ipcon = new IPConnection(host, port); // Can throw IOException
	BrickletLinearPoti poti = new BrickletLinearPoti(UID); // Create device object
	// Add device to ip connection
	ipcon.addDevice(poti); // Can throw IPConnection.TimeoutException
	// Don't use device before it is added to a connection
	// Set Period for position callback to 0.05s (50ms)
	// Note: The position callback is only called every second if the
	//       position has changed since the last call!
	poti.setPositionCallbackPeriod(10);
	// Add and implement position listener (called if position changes)
	poti.addListener(new BrickletLinearPoti.PositionListener() {
		public void position(int position) {
			System.out.println("Position: " + position);
			//Runtime rt = Runtime.getRuntime();
			//rt.exec("amixer sset Master " + position + "%");
			//rt.exec("mkdir Test");
  try
  catch(Exception e)
   System.out.println("Exception fehler beim setzen der lautstärke mit alsa");
	System.out.println("Press ctrl+c to exit");
	ipcon.joinThread();
