xsherlock Geschrieben September 18, 2015 at 19:31 Geschrieben September 18, 2015 at 19:31 Not sure if that is a bug or a feature? I define Temp sensor wit default xx.y precision. Number GF_Living_Temperature "Temperature [%.1f C]" <temperature> (GF_Living) {tinkerforge="uid=qnM"} I would expect that when acccessing those from the Rest interface it will be already rounded but it is not. <item> <type>NumberItem</type> <name>GF_Living_Temperature</name> <state>26.68</state> <link> Is that intended? Maciej Zitieren
theo Geschrieben September 18, 2015 at 19:45 Geschrieben September 18, 2015 at 19:45 Hi Maciej, I'm the developer of the openHAB Tinkerforge binding. Unfortunately I'm not familiar with the REST interface. I think this question is not TF specific but a general openHAB REST interface question. Therefore your chance to get a good answer is better if you ask the openHAB community at https://community.openhab.org Regards, Theo Zitieren
xsherlock Geschrieben September 19, 2015 at 19:09 Autor Geschrieben September 19, 2015 at 19:09 The rest interface is available over http://xxx.xxx.xxx.xx:8080/rest/items It give you back state of all the items in XML. it is an integral part of openhab. So is that true that a your binding is not looking at all at the sensor state formatting parameters in the .items file and just passes to openhab full precision? is that with all the other bindings? Fixing that afterwards in the openhab is quite a pain as requires creating a rule executing on every update. Would you consider adding a parameter to binding in order to to return rounded result? This sensor has so much jitter that last digit is meaningless anyway. I would also "fix" the current/voltage binding to give an option to return, voltage/current/power in V/A/W with definded precision and not the millis. Zitieren
