xsherlock Geschrieben September 3, 2015 at 22:59 Geschrieben September 3, 2015 at 22:59 If I power the stack with Step-Down Power Supply brick with 12V and that Voltage is passed to the MAster Brick. Do I still need external power supply conected to the Analog out 2 bricklet to make 0-10V signal? Maciej Zitieren
borg Geschrieben September 4, 2015 at 06:22 Geschrieben September 4, 2015 at 06:22 Yes you do! There are only 5V and 3.3V rails on the Bricklet connector, so the 12V can't be given to the Bricklet. Zitieren
