JavaLaurence Geschrieben August 21, 2015 at 18:05 Geschrieben August 21, 2015 at 18:05 Hi, Looks like the available Load cell weighing range tops out at 50kg. Unfortunately, most adults weights lie within 50-100kg, so are there any plans to offer 100kg max weight Load cells? Thx. Zitieren
photron Geschrieben August 24, 2015 at 11:03 Geschrieben August 24, 2015 at 11:03 You could build a scale for 100kg using two 50kg load cells and two Load Cell Bricklets and add the measurement of both for the final result. Zitieren
alrhr Geschrieben November 11, 2015 at 20:50 Geschrieben November 11, 2015 at 20:50 You could also buy load cells from other sources e.g. www.bosche.eu. Zitieren
