You might try this:
https://github.com/PlayWithIt/TFStubserver (without user interface)
https://github.com/PlayWithIt/TFStubViz (a simple user interface)
Not all devices are supported yet ... (MotionDetector is supported (also in UI).
There is a german description for it with an example:
http://www.tinkerunity.org/wiki/index.php/DE/Projekte/Stackemulator_%28stubserver%29
Hi JavaLaurence, Hi kinfkong,
some weeks ago I started to develop a simulator written in Java. It is primary meant for writing unit tests. As soon the dev has beta status I will publish it to github. @JavaLaurence I'm interested in your simulator-esque material, may be we could join the forces.
Regards,
Theo
@Theo: I'll describe what I've done..
First of all, I wanted all concrete TF classes for bricklets to become interfaces. Chiefly so that I could have multiple implementations (e.g. one bound to the real hardware, another bound to an emulated bricklet, a unit test mock, etc.)
To obtain those interfaces, I wrote a code generator that parses the official TF JAR, and generates the interfaces, and a bunch of other things (like concrete classes wrapping the TF bricklet classes, and implementing the interfaces).
I also wrote a few (not many) emulated bricklets. E.g. the LCD bricklet, various sensors.
The end result is that I can write TF applications that are interface-based, and which can trivially switch execution between emulated and real hardware.
By the way, it's kind of ironic that my approach is code generation-based, because Tinkerforge also uses a code generator as their foundation for language-neutral description of all their devices.
@JavaLaurence,
first of all sorry for the delay.
I used a different approach, I think it's more like TFStubserver does it: I wrote a replacement for the brickd.
It's a TCP Server which behaves like the original brickd but with data from emulated hardware devices.
The emulator device classes are generated with a python generator like the other TF language bindings. The generator uses the device descriptions of the TF generator stack. I started the development by rewriting the TF java bindings generator.
Writing over 65 device classes by hand is just to time consuming, boring and error-prone. But writing the generator is also a challenge ;-(.
The core TCP server and helper classes are hand coded. The emulator is still not ready and has a lot of rough edges but I'm preparing a github project to provide some insights. Hopefully I can finish this before going on holidays for 2 weeks.
Regards,
Theo
So your generator is written in Python? If so, then I think we've got a language barrier blocking any merging of efforts.. Long live the Babel tower of languages (somewhere I read there's even a programming language that has to be typed in Arabic.. it clearly is never going to stop).
