xsherlock Geschrieben August 6, 2015 at 22:48 Share Geschrieben August 6, 2015 at 22:48 is the persistance option with the database running on the image 1.7 openhab install? Maciej Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben August 11, 2015 at 16:40 Share Geschrieben August 11, 2015 at 16:40 By default no openHAB persistence addon is install. But you can use the RED Brick console tab in Brick Viewer to install any openHAB addon you need using apt-get. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
