Tomo59 Geschrieben August 5, 2015 at 21:54 Geschrieben August 5, 2015 at 21:54 Hello, for many hardware project in tinkerforge, when we open the schematics inside kicad we get a message saying that the library "special" is missing. Actually, there was a problem in kicad solved on may 22nd regarding this library problem. See https://forum.kicad.info/t/the-following-libraries-were-not-found-special-solved/870/2 and http://bazaar.launchpad.net/~kicad-product-committers/kicad/product/revision/5678 (the file template/kicad.pro). At least industrial-dual-0-20ma-bricklet and ac-current-bricklet project have this problem. I attach a patch fixing the problem for ac-current-bricklet. Regards. Thomas.patch_lib_special.diff Zitieren
ossiostborn Geschrieben January 19, 2016 at 19:29 Geschrieben January 19, 2016 at 19:29 until now I could find that problem. I did try Industrial Out. Pls fix. Missing also the last LIBS:industrial-do4-cache. So the OptoCoupler is shown as |?| in Schematic. Zitieren
batti Geschrieben January 20, 2016 at 09:02 Geschrieben January 20, 2016 at 09:02 Hello, many thanks for the hint. Actually this problem will occur in many of our projects. I think the only problem is, that the special library is missing in newer kicad versions, so it has to be removed from the library configuration of any project. As far as I know there should not be missing any symbols when doing this. This does not have a high priority for us, since it can easily be fixed by the user. Kind regards, Bastian Zitieren
