gazroo Geschrieben July 18, 2015 at 12:08 Geschrieben July 18, 2015 at 12:08 Hi all, For reasons I won't go into just now, I need to use the TCP/IP API for my TinkerForge project. I'm using Java as my programming language to create and send the UDP packets to the Master Brick. The Brick/Bricklets are all live and can be viewed in the TF viewer. I have checked to make sure that the Master Brick can be pinged (it can), and that my byte sequences (for the UID) are correctly orderred (little-Endian). I'm only sending the simplest of 8-byte commands (without payload), i.e. asking the Master Brick for its Ethernet status, or asking a Temperature bricklet for its current temperature, but I'm just not getting any responses at all on the socket receive() call. Can anyone suggest what else I can try, or some other way of debugging or making progress ? Please ? Thanks ! Zitieren
remotecontrol Geschrieben July 18, 2015 at 17:14 Geschrieben July 18, 2015 at 17:14 You wrote send the UDP packets to the Master Brick, but you mean: you send TCP/IP packets to the brickd service or directly to a master with an ethernet extension? You'll need a TCP socket, not an UPD socket. You followed this instruction: http://www.tinkerforge.com/de/doc/Low_Level_Protocols/TCPIP.html#llproto-tcpip? You should dump your data packet in your code first, then you can compare which bytes sequence you're sending. Zitieren
gazroo Geschrieben July 19, 2015 at 11:03 Autor Geschrieben July 19, 2015 at 11:03 My fault, and I apologise! I get involved in developing drivers for many different projects and I get so used to assuming UDP that I didn't read properly and just went ahead in creating a DatagramSocket. Everything working now - great product! Thanks Zitieren
