I've manually installed the drivers on my Win7 64bit pc, like it was said in the tutorial but I always get an error when I press "connect" in the brickv (see screenshot).
Does somebody have an idea what could be the problem? I've restarted my pc several times and also disabled my virus scanner and firewall but the issue remains. Or is Win7 64bit not supported by the Brickd? I couldn't find any details on this so...
It works under Win7 64Bit.
Did you check your host, the port and that the brickd is running?
The host should normally be localhost (if running from the same computer)
Port should be left unchanged (I don't remember the default)
To see whether the brickd is running go to
Start -> Rightclick on "Computer" -> Manage.
You get a window where you can navigate through a tree at the left side:
Services and applications -> Services
In the list search for brickd and check whether the status is "Running".
Thanks for the quick reply. I've then checked the services and the Brickd wasn't in the list. So the mistake I made was that I didn't closed my virus scanner when installing brickd. Because you said to look in the services I realised what I did wrong.
So thanks for the help
