bixator Geschrieben May 22, 2015 at 15:48 Geschrieben May 22, 2015 at 15:48 Hi, I'm trying to connect two Tinkerforge Stacks using the RS485 extensions. Things work fine when I'm using a master brick on the master RS485 side, and I can browse the bricklets connected on the remote stack. Moving the master 485 to a RED Brick, no remote bricks get listed. So, is this a supported configuration ? How can I debug this issue (log messages for RS485) ? BTW, I'm using the latest RED Brick Image. Thanks for your help. Zitieren
borg Geschrieben May 25, 2015 at 21:33 Geschrieben May 25, 2015 at 21:33 Mh, have you tried one of the recommended baudrates? http://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick.html#rs485-extension The A10s processor on the RED Brick can unfortunately only reach a few baudrates precisely. Zitieren
bixator Geschrieben May 26, 2015 at 06:21 Autor Geschrieben May 26, 2015 at 06:21 Hi, Thanks for your reply. Yes, I've tried the default baud rate (please note that the cable length between the two stacks is about 1 meter!) and tried then to lower it to 100000. Nothing changed. Again, this setup works fine if I replace the RED brick by a Master Brick. Is there any debug flag I could turn on or specific files to watch for RS485 extension errors ? Thanks. Zitieren
photron Geschrieben May 26, 2015 at 09:24 Geschrieben May 26, 2015 at 09:24 See brickd.log on the RED Brick: http://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick.html#system-logs Zitieren
bixator Geschrieben May 26, 2015 at 16:08 Autor Geschrieben May 26, 2015 at 16:08 hi, Mh, have you tried one of the recommended baudrates? http://www.tinkerforge.com/en/doc/Hardware/Bricks/RED_Brick.html#rs485-extension The A10s processor on the RED Brick can unfortunately only reach a few baudrates precisely. That was it indeed, I was wronlgy using 1000000 which is not in the list of recommended baud rates. I moved to 100 000 ant it works fine now. Does setting higher baud rates implies higher CPU load on the RED brick or is this handled transparently by the RS485 Extension ? BTW, the RED brick is very impressive, so is the whole software which is packaged with it. Very nice product. Thanks. Zitieren
