Hi Guys,
I just got my master brick and a couple of other bricklets today and they work well with the brick daemon and viewer combination. I also could read out values from the temperature bricklet in Python.
Problem:
I need to integrate the temp sesnsor bricklet with a project in C++. I followed the instructions given on this page. http://www.tinkerforge.com/en/doc/Software/API_Bindings_C.html#api-bindings-c
The directory structure etc. is taken care of. I have also added -
#include <cstdint>
#include <stdint.h>
and
using namespace std;
I am still getting over a hundred instances of these two errors:
  • error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
  • error C2146: syntax error : missing ';' before identifier 'header'
I know it has to do with C -> C++ bindings. The question is, has anybody already found a solution to this?
Yes, I changed the names from c to cpp.
Update: I created a blank project in VS2013 and now I get only some linker errors in the ip_connection.obj
Any idea how I could solve this?
Thank for the reply  :)
