If I understand correctly, I could use the RS485 extensions to have
one or more "remote" stacks which I could get access to from a
single brickd instance. Is this correct ?
Is there anyway to achieve the same "distributed stacks" managed
by a single brickd instance over Ethernet this time ?
Last, can we use the RS485 extensions with 2 wires only ?
Thanks.
Yes, exactly!
With the Ethernet Extension you need 0 external instances of brickd. In case of Ethernet you connect directly to the IP of the Ethernet Extension. The Ethernet Extension itself provides brickd.
Thanks.
No, you need 3 wires.
Thanks a lot for your quick reply.
Unless I'm wrong, a client application would need to connect to each
brickd instance running in the Ethernet Extension, which I'd like to
avoid.
So, I guess that there is no "brickd to brickd" protocol ?
Thanks.
So, does this means that the RS485 Extension does not support half duplex ?
Does this mean also what we can't connect a RS485 extension to
a non-TKF 485 device ?
Thanks.
avoid.
Right, there is no brickd to brickd protocol, you need to open a IPConnection per Ethernet Extension.
The third connection is for GND, it will likely not work well if you don't connect GND.
Still on the RS485 topic, I'm planning to build a "remote stack" with:
  • a RS485 master extension
  • a Servo Brick
  • 4 PTC bricklets
  • a Dual Relay Bricklet
  • 2 master bricks
  • a setp down power supply brick
Is this remote access over RS485 going to "stand the load" ?
I suspect that the PTC bricklets could generate bunch of
trafic...
Thanks.
