thicks Geschrieben March 18, 2015 at 06:26 Geschrieben March 18, 2015 at 06:26 I would like to replace the 91 ohm / 25 ppm shunt resistor on the Current Loop Bricklet with a Vishey Foil Resistor. I am looking for something with a lower TCR that could be easily swapped out. Maybe 5ppm or less. If it is not exactly 91 ohms then I will modify the Bricklet Firmware accordingly. Any suggestions? Zitieren
batti Geschrieben March 19, 2015 at 10:05 Geschrieben March 19, 2015 at 10:05 If you change the resistor value keep the maximum input voltage of the ADC in mind. Bastian Zitieren
