A very new python programmer here who has built the Tinkerforge weather station connected to a Raspberry Pi.  I am starting to tinker with the Tinkerforge code and want to implement the is_backlight_on function for the LCD.  I more often than not get a timeout error when I call this function; sometimes it works but mostly not.
Any help would be appreciated for a newbie!
Here's the code ...
#!/usr/bin/env python
# -*- coding: utf -8 -*-
HOST="localhost"
PORT=4223
UID="ogH"
import time;
from tinkerforge.bricklet_lcd_20x4 import LCD20x4
# Callback functions for button status
def cb_pressed(i):
    print('Pressed: '+ str(i))
    BacklightON = lcd.is_backlight_on()
    print(BacklightON)
if __name__ == "__main__":
    ipcon=IPConnection()    # Create IP connection
    lcd=LCD20x4(UID,ipcon)  # Create device object
    ipcon.connect(HOST,PORT)    # Connect to brickd
    # Register button status callback to cb_pressed
    lcd.register_callback(lcd.CALLBACK_BUTTON_PRESSED,cb_pressed)
    # lcd.backlight_off()
    print(BacklightON)
    while True:
        n=0
                    # Line 0
        Line="Button 0: MAIN MENU"
        # Determine start position to be centred
        # Position=(20-len(Line))/2
        Position=0
        # Write Line 0
        lcd.write_line(0,Position,Line)
        # Line 1
        Line="Button 1: DATE/TIME"
        # Write Line 1
        lcd.write_line(1,Position,Line)
        # Line 2
        Line="Button 2: WEATHER"
        # Write Line 2
        lcd.write_line(2,Position,Line)
and here's the error message ...
False
Pressed: 0
Exception in thread Callback-Processor:
  File "/home/pi/weather_station/tinkerforge/ip_connection.py", line 938, in send_request
    response = device.response_queue.get(True, self.timeout)
  File "/usr/lib/python3.2/queue.py", line 193, in get
    raise Empty
queue.Empty
During handling of the above exception, another exception occurred:
  File "/usr/lib/python3.2/threading.py", line 740, in _bootstrap_inner
    self.run()
  File "/usr/lib/python3.2/threading.py", line 693, in run
    self._target(*self._args, **self._kwargs)
  File "/home/pi/weather_station/tinkerforge/ip_connection.py", line 812, in callback_loop
    self.dispatch_packet(data)
  File "/home/pi/weather_station/tinkerforge/ip_connection.py", line 793, in dispatch_packet
    cb(self.deserialize_data(payload, form))
  File "/home/pi/weather_station/test_lcd.py", line 17, in cb_pressed
  File "/home/pi/weather_station/tinkerforge/bricklet_lcd_20x4.py", line 123, in is_backlight_on
    return self.ipcon.send_request(self, BrickletLCD20x4.FUNCTION_IS_BACKLIGHT_ON, (), '', '?')
  File "/home/pi/weather_station/tinkerforge/ip_connection.py", line 947, in send_request
    raise Error(Error.TIMEOUT, msg)
tinkerforge.ip_connection.Error: -1: Did not receive response for function 5 in time
Many thanks borg.
Your problem is that the code in your while loop runs as fast as it can. This will fill up all of the buffers and it is not possible for the callbacks to come through anymore.
Try to add a small sleep at the end of the while loop, like this:
    while True:
        n=0
        # Line 0
        Position=0
        # Write Line 0
        # Line 1
        # Write Line 1
        # Line 2
        # Write Line 2
        time.sleep(0.1)
