rich2387 Geschrieben January 22, 2015 at 12:07 Geschrieben January 22, 2015 at 12:07 Hi All I've been using 2 PTC bricklets connection to my PT1000s for about 6 months now without any problems. However, when I just connected the two i'm using the brickviewer was randomly reading -240 degrees for one when it should have been reading 18 degrees like the other bricklet. I've rescrewed all 4 terminals in case they were lose but this doens't seemed to have fixed the problem. Anyone got any ideas on what might be the issue here? Thanks Rich Zitieren
borg Geschrieben January 22, 2015 at 13:39 Geschrieben January 22, 2015 at 13:39 Perhaps there is a small "cable break" in one of the Pt1000? Have you tried wiggling the cables, can you reproduce the problem if you do this? Zitieren
