after connecting my (new) red brick via USB to a windows PC and configuring using the Brick Viewer. I rebooted the brick BUT ...the Green Light is ON (Linux bootmodus) but not blinking (Linux ready). Can also not connect via the Brick Viewer. The Brick has a wlan adapter and is reachable using ping.
Any hints?
pls find the logs.
In the mean time:
* connected a master brick with several bricklets, a monitor with keyboard and mouse.
* Checked using lxterminal if brickd was running > is not.
* Started the brickd using sudo brickd.
* Brickv now shows the Red Brick but not the extensions.
* Did also a sudo apt-get update and upgrade plus reboot > but after reboot brickd is not running.
* Rebooted again > brickd not running > opened lxterminal > started brickd using sudo brickd > started brickv > connected via ipaddress > the masterbrick and connected UIDs are found (red_stack.c:506 SPI stack slave discovery done. found 1 slave with 4 UIDs)
* So, the question is why brickd stops and can not find the slaves during boot.
brickd.log
2014-12-29 17:30:26.604795 <I> <main_linux.c:275> Brick Daemon 2.2.0+redbrick started (daemonized)
2014-12-29 17:30:28.222705 <I> <red_extension.c:482> Could not find Extension at position 0
2014-12-29 17:30:28.223231 <I> <red_extension.c:482> Could not find Extension at position 1
2014-12-29 17:30:28.227047 <I> <redapid.c:306> Connected to RED Brick API Daemon
2014-12-29 17:30:28.734749 <I> <red_stack.c:506> SPI stack slave discovery done. Found 0 slave(s) with 0 UID(s) in total
2014-12-29 17:35:01.536539 <I> <red_stack.c:526> Starting reinitialization of SPI slaves
2014-12-29 17:35:03.586592 <I> <red_stack.c:506> SPI stack slave discovery done. Found 0 slave(s) with 0 UID(s) in total
redapid.log
2014-12-29 17:30:26.418443 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2014-12-29 17:30:28.226844 <I> <network.c:97> Brick Daemon connected
2014-12-29 17:42:15.375909 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2014-12-29 17:42:17.184630 <I> <network.c:97> Brick Daemon connected
2014-12-29 17:56:14.922549 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2014-12-29 17:56:16.734145 <I> <network.c:97> Brick Daemon connected
2014-12-29 17:57:15.531784 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2014-12-29 17:57:17.344387 <I> <network.c:97> Brick Daemon connected
2014-12-29 17:58:15.805319 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2014-12-29 17:58:18.382527 <I> <network.c:97> Brick Daemon connected
2015-01-03 15:16:23.068630 <I> <brickd.c:45> Brick Daemon disconnected by peer
2015-01-03 15:16:24.705548 <I> <signal.c:53> Received SIGTERM
2015-01-03 15:16:24.705875 <W> <session.c:165> Destroying session (id: 1) while it is still tracking 3 external reference(s) to the following objects (logged on debug level):
2015-01-03 15:16:24.706265 <I> <main.c:383> RED Brick API Daemon 2.0.0 stopped
2015-01-03 15:16:35.929036 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 15:16:37.740076 <I> <network.c:97> Brick Daemon connected
2015-01-03 16:04:03.548469 <W> <api.c:957> Unknown function ID 250
2015-01-03 16:06:16.246472 <I> <brickd.c:45> Brick Daemon disconnected by peer
2015-01-03 16:06:18.928020 <I> <network.c:97> Brick Daemon connected
2015-01-03 16:06:19.650473 <W> <api.c:957> Unknown function ID 250
2015-01-03 16:07:21.713381 <I> <brickd.c:45> Brick Daemon disconnected by peer
2015-01-03 16:07:24.408626 <I> <network.c:97> Brick Daemon connected
2015-01-03 16:07:25.588723 <W> <api.c:957> Unknown function ID 250
2015-01-03 16:07:56.620711 <W> <api.c:957> Unknown function ID 250
2015-01-03 16:10:14.047589 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 16:12:14.093732 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 16:21:15.155989 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 16:21:14.097470 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 16:30:15.359022 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 16:30:15.524451 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 17:02:14.505632 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 17:08:14.474640 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 17:08:14.849923 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 17:17:15.552346 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 17:26:57.576512 <I> <signal.c:53> Received SIGTERM
2015-01-03 17:26:57.577033 <I> <main.c:383> RED Brick API Daemon 2.0.0 stopped
2015-01-03 17:27:11.858495 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 17:30:47.040953 <I> <network.c:97> Brick Daemon connected
2015-01-03 17:33:32.567326 <I> <brickd.c:45> Brick Daemon disconnected by peer
2015-01-03 17:33:35.270745 <I> <network.c:97> Brick Daemon connected
2015-01-03 17:35:27.202084 <I> <brickd.c:45> Brick Daemon disconnected by peer
2015-01-03 17:35:28.597477 <I> <signal.c:53> Received SIGTERM
2015-01-03 17:35:28.597813 <W> <session.c:165> Destroying session (id: 3) while it is still tracking 16 external reference(s) to the following objects (logged on debug level):
2015-01-03 17:35:28.598384 <I> <main.c:383> RED Brick API Daemon 2.0.0 stopped
2015-01-03 17:35:41.576397 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
2015-01-03 17:39:25.524075 <I> <network.c:97> Brick Daemon connected
That is strange. The latest brickd log is from December 29th, while the latest redapid log that says that brickd connected is from January 3rd.
I don't know how that could possibly happen :).
If you delete the brickd.log and reboot, is there a new one written?
deleted the files and rebooted. Logs below. Seems an issue with server socket.
SOLVED: Actions taken: started brickd > started brickv > in settings brick daemon found the listen address 192.168.0.24 > changed to 0.0.0.0 > saved > rebooted the red brick > brickd running.
Thanks for your help
BRICKD
2015-01-04 17:53:52.471385 <I> <main_linux.c:275> Brick Daemon 2.2.0+redbrick started (daemonized)
2015-01-04 17:53:52.484484 <E> <network.c:202> Could not bind IPv4 server socket to '192.168.0.24' on port 4223: EADDRNOTAVAIL (99)
2015-01-04 17:53:52.484689 <E> <network.c:322> Could not open any socket to listen to
2015-01-04 17:53:52.485051 <I> <main_linux.c:392> Brick Daemon 2.2.0+redbrick stopped
REDAPI
2015-01-04 17:53:52.151358 <I> <main.c:309> RED Brick API Daemon 2.0.0 started (daemonized) on 1.3 (full) image
If you put "192.168.0.24" into the listen address, brickd can only be accessed by the IP "192.168.0.24". Which means that redapid can't connect to brickd (since it connects through localhost).
Thank explains it indeed 8).
